Old 08-11-2010, 05:39 AM
beater68427 beater68427 is offline
Default Big Block Motor mount question???
On my 68 Camaro the BB frame mounts are approx 2-5/8 wide the motor mounts are 2-3/8 wide and the application shows 68-70 but are not correct at all, When I did the conversion to BB on my 71 Nova I used 69 Camaro frame mounts and the same motor mounts I have now and worked great. Im sure someone has had this problem any clues on a correct motor mount?
Old 08-11-2010, 02:29 PM
BARRY BARRY is offline
Yenko Premier Member
Default Re: Big Block Motor mount question???
1968 camaro big block are NOT,,, the same as 1969 and newer ihad the same problem
Barry Allan
Old 08-11-2010, 03:41 PM
69 Post Sedan's Avatar
For Big Blocks....1967-1968 Camaro and 1968 Nova are the same. 1969 Camaro and 1969-1970 Nova are the same.
1968 Schwinn Orange Krate
1969 Schwinn Pea Picker
1968 Schwinn 5-Speed
1970 Schwinn 3-Speed Deluxe
1973 Schwinn 5-Speed Suburban
All Original Paint Bikes
Old 08-11-2010, 05:12 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: BARRY</div><div class="ubbcode-body">1968 camaro big block are NOT,,, the same as 1969 and newer ihad the same problem </div></div>
I figured that out quite early but not finding a part number for the 68 mount that is correct, seems the 69-70 narrow style keeps coming up.
Old 08-11-2010, 05:34 PM
jasonL78 jasonL78 is offline
This might help. GM discontinued these a couple of years ago. I would check with your local GM dealer some one may have them on the shelf. I went through the same problem with my 68 L78 Nova.
Hope this helps!
Looking for the next project.
Old 08-11-2010, 05:35 PM
Think I found it # 2285 for 67-8 and # 2283 Duralast DER and Anchor numbers most books show 2283 for 67-70 396 70 up 402 wich is incorrect.
Old 08-11-2010, 05:37 PM
Jason Thanks!! I just figured out the numbers the same time you were posting. #2285 is the correct replacement to the discontinued GM unit.
Old 08-13-2010, 06:56 AM
For reference,
Top 3912598 RH &amp; 3912597 LH 67-68 Big Block engine frame mounts.
Middle 3980942 RH &amp; 3980941 LH 69-70 Big Block engine frame mounts.
Bottom 3980938 RH &amp; 3955183 LH Small Block engine frame mounts.
Greg
