Old 08-01-2010, 05:28 PM
PeteLeathersac's Avatar
Default Re: Engine Stalling when Braking
What happens if you try starting the car while your foot's on the brake pedal?.
[img]<<GRAEMLIN_URL>>/dunno.gif[/img]
~ Pete
Old 08-01-2010, 09:27 PM
Rob_M Rob_M is offline
The engine does NOT stall when I use the brakes going backwards, but it does stall when I use the parking brake to stop when going forward. That basically eliminates the brake light switch theory. I did check for any wiring interference and I didn't see any. I also checked the wires while the car was idling - shaking them and so forth and nothing. The car idles just great!
As an example, our driveway is at the top of a hill and if I let the car go backwards and hit the brakes it doesn't stall. Here's the interesting part, if I am going backwards and goose it a little the car dies. This strongly suggest that this problem only happens when the car is accelerated in one direction. Going in reverse and hitting the gas produces the same 'motion' (the car and occupants being accelerated toward the front of the car), while going forward and braking.
When I am driving the car and put it in neutral I can pump the brakes and the engine will start to stall and recover each pump that I do. When it is idling I can hold the brake pedal all day long and the car does not die. It also starts with my foot on the brake pedal.
I know this hard to believe but that is what it does......
I wired the MSD box into the battery, bypassing the rest of the car and it still does it. I assume that only leaves the ignition part at fault. One thing I did noticed is my MSD Blaster coil is mouinted sideways with the bottom of the coil facing the front of the car. I plan on trying a different coil to see what happens. After that I will reinstall my old distributor. (I installed a new MSD ignition this spring...)
At this point I'm just trying everything that sounds logical....
Old 08-01-2010, 11:51 PM
x  Baldwin  Motion's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: PeteLeathersac</div><div class="ubbcode-body">What happens if you try starting the car while your foot's on the brake pedal?.
~ Pete
</div></div>
Has the motor and trans been out recently? Sure sounds like some wire is being pinched somewhere during deceleration. Check all wires around back of motor, top of trans, starter, exhaust. What type of trans ? Sure is a puzzler. [img]<<GRAEMLIN_URL>>/hmmm.gif[/img]
Old 08-02-2010, 03:38 AM
Do you have all of those braided copper ground straps that run from the block to the firewall, and from the block to the subframe? Without those, the power will backfeed up into other circuits.
Old 08-04-2010, 04:24 AM
OK. Here are more of the 'things' that I tried with no success.
1. Changed the coil, didn't think it would do anything but I tried anyway.
2. Removed the brake light switch, same.
3. Spent time under the dash and went through all the wires and they all looked tight and connected. Nothing was near the brake pedal.
4. Looked at the wiring under the hood and it looked good there. I do have a copper ground coming from the firewall to the head and that was connected. I do NOT have any other ground straps though.
5. Car starts and idles beautifully when I have my foot on the brake.
The car has a manual transmission in it and there are no wires going to it. No backup switch or anything. This weekend I will install the motor to frame grounding strap. The thing is the car hasn't had that strap since I have had the car.....
Like I mentioned in my previous post, I took my ignition, (MSD box 6AL and distributor), and connected it directly to the battery which I assume, tell if I am wrong here, will bypass the rest of the wiring harness. When I did that the car still died. It makes me think the problem is within the ignition itself..... When the engine does die my voltage meter reads ~14 volts. If I had a bad ground would my meter still read 14v?
My next step is putting a different distributor in it.... I want to eliminate everything that I can....
Thanks - Rob
Old 08-04-2010, 06:25 AM
PxTx's Avatar
PxTx PxTx is offline
I am a little suspicious of the distributor at this time. Why don't you pull it out and look it over. There could be a broken ground wire, and as the advance moves things, the problem occurs.
Paul III
Old 08-04-2010, 06:58 AM
Plowman's Avatar
Plowman Plowman is offline
Try the fire wall fuse block connectors [on the engine bay side]. I think there is a bolt that hold's half of it tight. See if it is loose. Also see if it is clean inside.
Old 08-04-2010, 03:38 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Plowman</div><div class="ubbcode-body">Try the fire wall fuse block connectors [on the engine bay side]. I think there is a bolt that hold's half of it tight. See if it is loose. Also see if it is clean inside. </div></div>
I'm thinking this plug too and better yet may be undoing it from the engine side to inspect and clean the connections..
Some of these were a 3/8&quot; bolt head and the engine side splits into separate sections that go to their respective assys...engine, nose lamp harness etc..
Check any other connections @ the firewall too as perhaps the mechanical side of brake application is flexing the metal enough to alter a ground or connection somewhere?.
Have you tried remotely grounding the engine to chassis/body w/ a booster cable yet?.
Also was the ignition dash lite on regardless of key position when you hotwired the coil?.
Lastly, when it quits and you immediately check the carb is there fuel at first pump and lots w/ subsequent pumps too?.
~ Pete
Old 08-07-2010, 12:48 AM
Got it!
After going through everything I could think of, I thought about switching out the battery from my 'Honda'. When I started playing with the battery in the Biscayne the engine died. Sure enough, when I tilted the battery forward the engine died, when I tilted it backwards nothing. That was it. The only thing I could figure was there was a bad cell that would short out when it was tilted in one direction only. Strange.
Thanks to all for their comments and support. If nothing else, I am much wiser and know my car a little better. [img]<<GRAEMLIN_URL>>/tired.gif[/img]
Rob
Go Green!!
Old 08-07-2010, 01:29 AM
Interesting...thanks for sharing the final resolution. It may save someone else from the trials that you went through
