Old 01-21-2010, 05:57 PM
PeteLeathersac's Avatar
Default Re: COPO 3963512 block. No VIN#
Not perfect but a couple good rules to go by when no listings are at hand;
- '70 model year & newer engines have the 3 digit suffix starting w/ a C for Cars and T for Trucks...'69 and older the 2 digit suffix w/ no C or T..
- When a Vin stamping is there count backwards from the end and the 8'th digit is the model year..
Welcome aboard Chris!.
~ Pete
Old 01-21-2010, 06:28 PM
steakandracingfuel steakandracingfuel is offline
thanks alot guys. well if it is a common block and not much use then using it as a race motor is not that bad then or if anyone is interested in taking it off my hands.
Chris Thornton
Old 01-21-2010, 07:08 PM
Zach Carter Zach Carter is offline
PM sent.
Zach Carter
1969 Biscayne L72 M22 Real
1972 Nova SS-Former Drag Car
Old 01-21-2010, 07:34 PM
thanks alot guys. also, just to clarify, some of my posts may sound obnoxious but thats how i find things out. ask alot and push people to explain so Einstein here will understand.
Chris Thornton
Old 01-21-2010, 07:37 PM
Pete. you have a pm.
Chris Thornton
Old 01-22-2010, 02:21 AM
Fast67VelleN2O's Avatar
ok ok. i see. but why does the cast# point to 427 and not list 454
What book are you reading your numbers from?
Day 2 is Life.
Old 01-22-2010, 05:30 AM
Nasty.
Chris Thornton
Old 01-22-2010, 03:00 PM
Unreal Unreal is offline
Just out of curiosity, are there any known 69 COPO Camaro with 3 letter code, e.g. CMN?
Old 01-22-2010, 10:50 PM
talwell talwell is offline
No - the COPO MN code was used for the 1969 427 4 Speed combination and MO for the automatic. The use of the 3 letter code began with the 1970 model year. This included the blocks and the rears.
Old 01-23-2010, 01:06 PM
Kurt S Kurt S is offline
But 69 Camaro had an extended model year. The later axles were 3 digits and some BB's were too. I have a service bulletin: 400 (meaning 402) engine released for 1969 Camaro. They talk about the 3 digit BB codes. I need to scan it soon.
But I've not seen a COPO with a 3 digit code.
Kurt S - CRG
