Old 01-13-2010, 08:55 AM
Default Re: TANK STICKER CORVETTE
Drill some starting holes in the empty and rinsed tank and then take a jigsaw/sawzall or tin snips and cut it out leaving a metal margin around the outside. Then you can take the cutout piece and finish the sharp edges on your bench grinder.
Howard
Old 01-13-2010, 04:02 PM
lwkitt427 lwkitt427 is offline
ALL GREAT TIPS GUYS I KNOW THAT WITH KNOWLEDGE OF THE GUYS HERE ON THIS SITE THAT I WOULOD GET SOME GREAT ANSWERS. I WILL KEEP EVERY ONE POSTED IF I GO LOOK AT THE CAR.
LES
Old 01-13-2010, 05:44 PM
TimG TimG is offline
If you have other paperwork, cover it and leave it on the tank after taking good pictures.
ORIGLS6 ORIGLS6 is offline
The best way is to leave it on the tank and install another tank. Just a opinion....
There's a good chance the tank has pin holes on the bottom anyway. I hardly ever saw a Corvette tank that didn't have an inch or so of water in the bottom.
I had to replace the tank in my '68 and still have it (with the sticker attached) stored above my garage. The car is long gone but much of the stuff I replaced is still around. BTW, Anyone need a complete smog pump and brackets for a '68 427 Corvette?
Old 01-13-2010, 06:03 PM
m22mike's Avatar
m22mike m22mike is offline
Maybe be off the topic a bit, but if one choses to cut or repair a tank, after it is cleaned out, through in a few pounds of dry ice. That will displace the 02 and may keep you off the local news too.
I have seen some old welders ( like Shoney. ) use this trick on small aircraft tanks.
