Old 12-07-2009, 02:36 AM
x  Baldwin  Motion's Avatar
Default HEI with stock size dist. cap ?
I switched the motor from my 65 Chevelle to the 69 Nova. I had an HEI dist (mid 80's style)on the motor and there is no clearance for this in the Nova. Is there something smaller I can use or do I have to go back the points distributor?
Thanks in advance for your help.
Old 12-07-2009, 04:46 AM
RPOLS3's Avatar
RPOLS3 RPOLS3 is offline
Default Re: HEI with stock size dist. cap ?
If you have to go back to points distributor due to size constraints but don't want the points - you can install an electronic conversion kit from somewhere like Lectric Limited. All fits under stock cap, no other wires protruding, etc. Not the cheapest solution maybe but.....
http://www.lectriclimited.com/mainpage.htm
Jake Dykstra
Dykstra Motorsports
Old 12-07-2009, 08:28 AM
Plowman's Avatar
Plowman Plowman is offline
You will have to get new wires,or MSD small cap for HEI wires is the best.
Old 12-07-2009, 04:06 PM
Chateau Slate 66 Chateau Slate 66 is offline
I have the Pertronix II in my stock distributor and it has been great. Another option is Dave's small body hei conversion in your stock distributor. I have not used him, but others seem to like his stuff.
http://www.davessmallbodyheis.com/
Old 12-08-2009, 07:06 PM
Thanks for the input!
Old 12-10-2009, 12:21 PM
Unreal Unreal is offline
I got a Dave's unit, and I like it because the components are available at any auto parts store. He does have to machine the underside of the body to square it, so don't use a "special" core. I bought one for $5 and sent it to him for modification.
