Old 09-21-2009, 04:54 PM
1969z280 1969z280 is offline
Default Re: Engine block stampings
Bob:
If someone restamped the block, why wouldn't they have made it a couple days later than the casting date? My opinion would be that it's probably the real deal. Good luck and enjoy it, Ed
... some old Chevrolets and Pontiacs.
Old 09-21-2009, 05:34 PM
Jonesy's Avatar
Jonesy Jonesy is offline
Furthermore, its not a restamp, so there is your example of being cast and built the same day.
Old 09-21-2009, 06:57 PM
bergy's Avatar
bergy bergy is offline
I don't believe that anyone has said that it's a restamp - I'm just saying that the owner could look at the time code on the block and demonstrate how it makes sense that it's not a restamp. Of course, now that god has spoken - there's no need for a technical discussion.
Old 09-21-2009, 07:17 PM
Jonesy's Avatar
Old 09-27-2009, 05:04 AM
JohnZ JohnZ is offline
We (NCRS) have documented a number of Flint small-blocks that were cast and assembled on the same day, and MANY that were assembled the day after they were cast. The Saginaw Foundry sent 55,000 iron castings to Flint V-8 every day, and those dedicated GM trucks ran 24/7. Machining at Flint V-8 ran on three shifts, and both assembly lines ran on two shifts (170 per hour on Line 1, 130 per hour on Line 2).
'69 Z/28
Fathom Green
CRG
Old 09-27-2009, 04:00 PM
bergy's Avatar
I agree Bob - I said that it was difficult ( as reinforced by the small number of instances that it happened) but not impossible. There were two Saginaw Foundries producing iron castings (one gray and the other ductile). Saginaw gray only ran two shifts and V8 blocks only ran at a rate of about 2500 molds per shift. The technical point is that you can tell by the casting clock if it was even possible for a specific case to make it to Flint in time for machining on the same day. For example, there's no way that an 11:00pm casting could get through processing and down to Flint for complete machining in one hour! I worked at Tonawanda, but traveled to our sister plants in St. Catherines and Saginaw quite a lot.
Old 09-28-2009, 08:55 PM
This is 'spot-on' per the date frames we see on the Deuces. I thought it was almost impossible for this tight of a date, but multiple Deuces have these tight dates. Now, we can tell rehits when the dates are not tight enough.
Old 09-28-2009, 10:35 PM
bergy's Avatar
Castings were not put into foundry inventory on a FIFO basis - there will always be legitimate blocks that have a large spread between cast date and machine date. Blocks that got set aside for allowable cosmetic welding as well as inventoried blocks sat around for quite a while. There will never, however, be second shift Saginaw castings that were assembled on the same day at Flint.
Old 09-28-2009, 11:45 PM
69 Post Sedan's Avatar
How many blocks were cast the day before, then, machined/stamped the next day while accidently stamping yesterdays date.
1968 Schwinn Orange Krate
1969 Schwinn Pea Picker
1968 Schwinn 5-Speed
1970 Schwinn 3-Speed Deluxe
1973 Schwinn 5-Speed Suburban
All Original Paint Bikes
Old 09-29-2009, 12:12 AM
PeteLeathersac's Avatar
That statement is very probable and could have more truth to it than we'll ever know!.
~ Pete
