Old 08-04-2009, 11:56 PM
Mr. Chevy's Avatar
Default Re: Starved For Fuel?
Thomas, if the AC plugs you are running are newer ones they are junk, believe me.. Thats what I was running and had all kinds of problems with them.. I threw mine in the trash, thats about all they are good for.. If they are old, NOS ones you should be OK...
I agree with Sully, if you want the carb. looked into contact Eric and send it to him for a rebuild or good check up!! Good Luck...
Rich
Old 08-05-2009, 01:44 AM
VintageMusclecar's Avatar
First check the float levels.
Next, check/replace the fuel filters in the float bowls.
If the car sits for extended periods, you might check to see if the sock in the fuel tank is getting clogged or varnished up.
Eric
Old 08-12-2009, 05:09 AM
Thomas Thomas is offline
I thought I had found the problem. The rubber fuel line which runs from the solid line coming from the tank to the fuel pump seemed a little long and appeared to have developed a slight "kink". It came as part of the fuel line kit that I installed over 10 years aago, so I never paid much attention to it.
I replaced it with a new and slightly shorter piece.
It took the car for a spin, and here is what I've found. The car "runs out of steam" somewhere around 4700 RPM, in any gear.
I have checked the float levels and they are okay.
Any ideas?
I was thinking of increasing the jet size in the carb.
Or...
Could it be an ignition problem like a weak coil?
The timing is set to 4 degrees and the dwell is 28 degrees
Thomas Schilf
'69 Camaro SS, L78, M22, 4.10 Posi
'69 Camaro E/SA
'00 Camaro SS Convertible
'04 Harley FXST
'80 Chevy Blazer (My first new vehicle)
Old 08-12-2009, 05:23 AM
69L34M20 69L34M20 is offline
It isn`t the jets. How about the valve springs? Try testing them for pressure.... may be float city... which could also cuase a backfire.
like someone mentioned....are you sure the secondaries are fully opening?
Old 08-12-2009, 05:46 AM
mfchassisworks mfchassisworks is offline
What is the fuel pressure during a run through the gears?
Old 08-12-2009, 06:00 AM
The engine was completely gone through shortly before I bought the car. I do realize that it is difficult to judge the quality of someone's work when the engine is buttoned up, but I find it difficult to believe that the valve springs could be an issue with less than 10,000 miles on them.
However, I have learned to never say never.
How would I go about testing the secondaries on a vacuum secondary Holley?
Just for the record, the people on this site have provided some great advice so far.
Thomas Schilf
'69 Camaro E/SA
'04 Harley FXST
Old 08-12-2009, 06:04 AM
There is no easy way for me to plumb a fuel pressure gauge into the stock fuel line setup, so at this time this is still an unknown.
I may have to figure out a way if all else fails.
Thomas Schilf
'69 Camaro E/SA
'04 Harley FXST
Old 08-12-2009, 02:20 PM
Chevy454 Chevy454 is offline
Any ideas?
Check to make sure your coil isn't wired backwards...car will still run, but takes a dump when under load.
Old 08-13-2009, 04:06 AM
ssscamaro ssscamaro is offline
fuel filter in bowls if still equipped.
Float levels!! Does the carb have secondary jet extensions? If so it MUST use a notched float. I had a 69 camaro holley carb without extensions going 1080s 124 put jet extensions in it and fell on its face 900 or so feet. the rear float couldnt drop far enough to let enough fuel in to replenish what was being used. Put in notched float( i always run my holleys with fuel right up to bottom of sight plugs and just a littel tricle if you bump the fender)set level and 1 tenth better 60 foot and 1070 127 mph...
Ryan
by the way i Have a stock Y block that i drilled and tapped for 1/8 npt on the bottom side. ran my fuel pressure guage in it a few times to see what WOT was reading. after i was happy with that took off guage and put a 1/8npt plug back in that you cant see unless you take Y block off.
also i have seen the old fuel sending unit 'socks" melt into mush with age...did that get replaced??
Old 08-13-2009, 05:56 PM
You mentioned it is a vacuum secondary..... Take a peak at the secondary spring. The real heavy ones will never allow the secondaries to fuly open. Try a trick kit and put in a yellow one....it opens fast and all the way.
