Old 05-29-2009, 01:47 AM
bkhpah bkhpah is offline
Default Re: Trim Tag Rivits
Most if not all the trim tags I have seen look nothing like the photo. The centers are open and the rivet folds around the back side. Then seam sealer is applied to the void left in the center of the rivet. I doubt there is a standard look to these. As for removal of the tag, if you do not and have it dipped, blasted, etc, you will ruin the tag instantly. Even a trip in the bead cabinet with to much pressure will warp a tag before you know you even did it. I have had cars in the shop with so much build up of paint on the tag it was un-readable. So much build-up that I thought the tag was a fake. The best way I know to clean the tag is with a mild paint stripper. Anything else and you will be looking at a repo tag..BKH
Old 05-29-2009, 02:04 AM
And I would suppose that if you needed to take a trim tag off for any reason...you could document the process fairly easily with a video camera...
Old 05-29-2009, 03:33 AM
resto4u resto4u is offline
I have seen rusted firewalls that you have to remove the tag to fix the rust or replace the upper cowl. Not a big deal if documented right, as bruce suggested video and witnesses. Roger
Old 05-29-2009, 04:23 AM
bergy's Avatar
bergy bergy is offline
Just FYI - The center of the rivit on the tag pictured has seam sealer protruding through it. The center was presumably open before the seam sealer was applied.
Old 05-29-2009, 09:43 AM
I've never been in any situation in which trim tag r/r was needed during resto. Maybe I've just been lucky, but I would have some serious reservations on ever doing so.
Having one chem-dipped isn't an option we would consider, and the ones I've had blasted I've covered every tag/# with several layers of duct tape as well as repeated instructions to the blaster not to go near it. When we had (the first and only) car soda blasted, they didn't listen very well and hit the tag. It looked damaged initially, but turned out okay.
Non-issue now as I do the blasting myself now (again). And if its built up with paint, just strip the paint as BH mentioned.
TheMuscleCarGuys.com
Old 05-29-2009, 04:22 PM
P.J. P.J. is offline
If you have documents and a history of the car and you need to replace the trim tag rivets its ok with me.You are lucky if your rivets and tag are ok after 40 years,
but what iffffff.I have seen rivets that were about to fall off from corrosion. Do you chance loosing the trim tag???
Surely if your cars history and documents are ify then yes
removing the tag is a no no.
PJ
