Old 04-16-2009, 08:22 AM
1969grb 1969grb is offline
Default Re: Gas Cap for '70 Nova
Sam, Your mailbox is full! Grady
Old 04-16-2009, 08:25 AM
Jack Seymour has experience with this I believe........
Seems to me that the Spectra Premium neck can be modified to accept the correct cap.
I can't say why Spectra Premium neck isnt correct for 70???
Chuck Sharin
[email protected]
69 Camaro COPO "recreation"
Old 04-16-2009, 08:39 AM
travlnz28 travlnz28 is offline
Is it normal for a "Vented" cap to allow pressure build-up. My 70 Chevelle does it. Should I drill the cap or just leave it alone?
Old 04-16-2009, 08:45 AM
ORIGLS6 ORIGLS6 is offline
Mine builds pressure ocassionally. If it gets to be a problem I just loosen it a bit. Just a personal opinion but I wouldn't drill an OE cap.
Old 04-16-2009, 09:23 AM
mockingbird812's Avatar
Grady - she's empty now!
Sam...
Old 04-16-2009, 05:58 PM
m22mike's Avatar
m22mike m22mike is offline
Don't drill your vented caps... ...I am quit sure they are designed to allow some positive pressure in the tank, it helps the crappy little fuel pump work better.
When I have been driving Black Beauty... ...and pull in for gaz, I always crack the cap for a few seconds to allow the tank to vent off. Never tried it after the car has set all night.
If you and try blowing through the hole on the back of a vented cap you will notice it requires a small amout of effort before you get any flow.
The vented cap also has a negative pressure relief built into it as well. You can check this function by sucking on that little round thing in the back of the cap..
For you guys that are not in touch with your masculine side or are
affraid of germs, use a Mighty Vac...
Old 04-16-2009, 06:17 PM
WOW Mike, learn something new about you every day! Is this how it is done?
Old 04-16-2009, 07:27 PM
JRSully JRSully is offline
I have a Spectra 70 model tank in my 70 Nova, and only the EEC cap (the wide one) fits, a standard cap will not fit, pain in ass. Somebody mentioned a fix for this,? I'm all ears and eyes, let me know
71 Porsche 911 Targa
Old 04-17-2009, 03:39 AM
67BelAir427 67BelAir427 is offline
Jim,
You must have had the exact same experience I had. We are not talking about a little pressure in the tank.That "vented" cap seals the tank tight. When I remove the cap you can see the entire tank "flex" as the vapor escapes. For sure you would blow that back through the carbs on a hot day and you'd be stuck. I too would like to hear from someone who has bought these parts and found a solution to the problem. Marc
Old 04-17-2009, 09:37 AM
Sam, These are the pic's of the cap that Mike had replated for the burgandy Nova.
Next is an NOS one note paper gasket.
Also check the cap on Charley's 70Z , it is the same as should be on your car according to the parts book. Grady
