Old 03-11-2009, 04:29 AM
68CamSS 68CamSS is offline
Default Re: Low oil pressure in ZL-1
Triple check the bearings.
Old 03-11-2009, 05:05 AM
69SSZL1's Avatar
69SSZL1 69SSZL1 is offline
Is this a new ZL-1 Chevy block 053 casting? it does use a relief valve under the oil filter. Make sure is was installed and staked in the correct hole as there are 2 holes it fits in. If not there, could be your problem.
Old 03-11-2009, 05:12 AM
Alss's Avatar
Alss Alss is offline
I dont remember puttng that in..do you have more info that I can use??
1969 Beaumont 540 th400 3.70
1968 Camaro ragtop LSA ZL1
Old 03-11-2009, 05:18 AM
69SSZL1's Avatar
Remove your oil filter and look at the block. There are 2 large (3/4"?) holes. 1 large hole should have a check valve in it or you will bleed pressure like crazy. The valve is availible thru Chevy Performance Parts-Scoggin Dickey knows what it is if you tell them its for ZL-1 block.
Old 03-11-2009, 05:21 AM
Alss's Avatar
thats got to be it!!..never put one in!!!
The Following User Says Thank You to Alss For This Useful Post:
DW31S (08-09-2019)
  #16
Old 03-11-2009, 05:29 AM
69SSZL1's Avatar
The relief valve part number is 25013759. This is the set-up on all ZL-1's. I would have to remove my oil filter to see which hole I put it in as I don't remember.
Old 03-11-2009, 05:33 AM
69SSZL1's Avatar
Check it, and if you don't have one in the block let us know.
Old 03-11-2009, 05:50 AM
Alss's Avatar
I know I did not put one in..Ill verify it in the AM and order that piece..many thanks!!
ALbert
Old 03-11-2009, 06:33 AM
Wow, this is better than any soap opera or game show. It actually has a happy ending (crossing my fingers at the moment). Alss, update us as soon as you know.
Old 03-11-2009, 07:24 AM
Joe69Camaro Joe69Camaro is offline
Sounds Like sound advise to me from 69ss ZL1... Lets check it out tomorrow.. Sounds like what is going on!!!! All the problems indicate the facts at hand... And lets go from there....
Tubbed 69 camaro
