Old 12-18-2009, 06:03 AM
kenwoodj7j kenwoodj7j is offline
Default Re: BE 0306 axle, what value?
Hi ask your friend if he would be interested in trading for a complete restored JL8 set up, front setup included dated QX 0305
Old 12-21-2009, 04:20 AM
10K? are you serious? I have one under my 73 firebird.Spring brackets were moved,has a spool and Moser axles in it.I dont have the service package posi unit or GM gear from it,but I did sell them a few years back and might be able to find them.Wowo,maybe I need to look for another rear.
Old 12-21-2009, 04:40 AM
COPO CARTEL COPO CARTEL is offline
Has your PM box filled up yet. Very desirable date 10 K is VERY strong money if the internals are not there. The housing is only 1/3 of the equation. Good Luck
Drive it ...Like you STOLE it !!
Old 12-22-2009, 07:09 PM
enio45 enio45 is offline
I bought one back in feb this yr....housing only for 7K then you need to buy the COPO Carrier , ring and gears for the inside for another 4-5K , so you have 11K in one and it still needs restored (bearing, axles and detailing). Pretty easy math here :-)
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
Old 12-22-2009, 07:44 PM
talwell talwell is offline
I have a BE rear dated 05/24/69 and is complete minus the original heat treated gears. The rear is in excellent condition, all the markings are crisp and clear and everything is there. The only thing changed appears to be the 5:13 gears. This was purchased at a swap meet 12 years ago and has been stored since. I will sell this rear for $9500.00 or once I get the ring & pinion I will have it restored and then offer it again.
