Old 11-16-2008, 08:14 PM
Unreal Unreal is offline
Default Re: 1968 CAMARO L-78 VALVE COVERS
Only focusing on the driver side one (single hole)I agree with Sully on not being correct for 70. I think this is a 69 only design, but not certain whether is was used in 68. The spark wire tower is in the correct position for a 69 Camaro, forward of the rear bolt hole. Chevelle was the same design, except that the spark wire tower was aft of the rear bolt hole. Missing, however, is the temp sending unit wire clip on the lower side. Could have been lost....look to see if there any weld marks.
Old 11-16-2008, 08:36 PM
HPMIKE HPMIKE is offline
Not to derail the thread...
But does anyone make a "cheater" taller version of that OE style chrome cover?? Need to hide some fancy valvegear
MB
Old 11-17-2008, 03:14 AM
There are extensions you can buy, that are about 1/2" thick. If you paint the piece and the lower gasket, they sort of blend into the block. Peter Klute did that for an L88 on one of his shows.
Old 11-17-2008, 04:03 AM
Those look correct to me. The bulge on the driver's side is correct and the spark plug wire stand is in front of the bolt hole. No clips for wires and drippers. It took me over 10 years to find a set for my car.
Martin Foltz
68 Camaro SS-396
Old 11-17-2008, 07:02 AM
169indy's Avatar
169indy 169indy is offline
Yes those covers pictured are a dead on match for mine on my 68 L-35 (86K mile). The stands (locations and layout) and slant are a dead on match.
1968
Jim
69 Los Z11
68 SS/RS 396/325
68 Los Z28
Old 11-18-2008, 04:26 AM
plumL78 plumL78 is offline
Those look like 68s. 67s have two clips for the temp sender on the intake side. 68s don't have any clips and 69s have one clip on the exaust side. Right side is the same on 67 68 69 except with ca. smog. The bump on the end is correct for first gen. and the spark plug stand in front of the bolton the left side is also correct on camaros. I don't know anything about 70s
Old 11-18-2008, 05:14 AM
CROSSRAMJL8 CROSSRAMJL8 is offline
Thanks for everyones input. Sounds like these are correctfor my car.
