Old 11-07-2008, 10:11 PM
firstgenaddict's Avatar
Default Re: Radiator cap restoration (AC)
I would use some safest rust remover and go from there if I didn't go with the soda.
~JAG~
NCRS#65120
NUMEROUS Lemans blue Camaros,
& a Chevelle or two...
Old 11-09-2008, 01:09 AM
k92 k92 is offline
I was referred by someone on this board to a guy who does a lot of corvette stuff. I cant remember his name right now,think he was from New Mexico. He did a really good job on my cap.
Old 05-27-2009, 02:06 AM
mockingbird812's Avatar
Jason - u mentioned above that you use a new Stant cap for new seals, etc. Can you go thru the procedures to install the new seals. Do you have to dismantle the vintage cap to install the new seals?
Thanks (p.s. your Windex and fine steel wool did the trick!)
Sam...
Old 05-27-2009, 02:26 AM
Sam,
Its been awhile since I have messed with a mechanical resto on one of these caps. I don't remember how I went about it but I think it involved a stant cap. There was a thread on this a year or two ago. I think it may have been Budnate who was talking about scavenging the yards for these caps and fixing them. I'm glad the windex and steel wool worked out well. I use windex for almost everything, sometimes even glass
Sorry I could not be more helpful,
Old 05-27-2009, 04:31 AM
budnate's Avatar
budnate budnate is offline
not me on this one.....I think Drifter is the cat your after...I am sure he will chime in after work,
Old 05-27-2009, 05:53 AM
juliosz's Avatar
juliosz juliosz is offline
Here's a before and after pic of the cap off of my 65 vette. The plating was done with a do-it yourself kit (Caswell).
[image][/image]
Old 05-29-2009, 05:15 AM
P.J. P.J. is offline
what kind of plating is it??? Nice Job.
If you need to change the seal and remove the rivet
will you use the same rivet or get a new one some where???
PJ
Old 05-29-2009, 06:01 AM
juliosz's Avatar
P.J., it's cadmium plated and the aluminum rivet is the original. A member of our local NCRS chapter did it and he's able to mask pieces of the assembly you don't want plated like the rivet. I didn't need to replace any seals on it yet but I plan to use what I can off of a new aftermarket cap.
