Old 09-08-2008, 11:25 PM
Default "Pilot" LS-6 engine dyno run resuls
We just got done doing the dyno run http://www.randrperformance.com on Mark Mitchell's (LateGreatU2) LS-6 engine. Of the three LS-6's I have had built and dyno run in the last year, this one smoked them all. Running through a completely stock and restored carb from Eric at http://vintagemusclecarparts.com , a restored distributor from Chris White, stock exhaust manifolds, stock intake and a cheap set of plug wires, the engine pulled 492 hp. I don't have the spec sheet yet so I am unsure what RPM the peak hp was at. Ron, who runs the dyno stated that through headers, a better (non OEM) ignition system, a 1" carb spacer and better plugs this engine should pull close to 525 to 540 hp. Keep in mind, this engine outside of an .060 overbore was built to stock specs using replacement OEM syle pistons, rods, cam, springs, valves, etc. The other two engnes were run through headers and both pulled around 470 if I recall correctly. I have a lot of faith in my engine builder (Total Engine, Bloomington, MN) and have used them for a long time as they have managed to bring a lot of my engines back from the dead over the years. Just thought I would share the run with you guys.
Old 09-08-2008, 11:36 PM
VintageMusclecar's Avatar
Default Re: "Pilot" LS-6 engine dyno run resuls
Stout #'s
Priveleged to be a part of the build.
Eric
Old 09-09-2008, 12:30 AM
Very cool Rick!!
Old 09-09-2008, 12:36 AM
ORIGLS6 ORIGLS6 is offline
WOW! Maybe I need a set of Cheap Plug Wires!!!
Old 09-09-2008, 02:43 AM
Very fitting that the "Pilot" car's engine should put out some impressive numbers!
Bill Pritchard
Old 09-09-2008, 02:49 AM
JLerum JLerum is offline
Great numbers Rick. What type of dyno are you guys using?
Jim
1970 LS-6 Chevelle
Going fast on Goodyear Polyglas.
12.21 @ 115.32 PSMCDR 2009
12.24 @ 114.30 PSMCDR 2010
Old 09-09-2008, 02:52 AM
http://www.randrperformance.com/dynoindex.htm Using Ron is great and provided Mark and I with a video down link so we could watch his dyno run live complete with audio.
My apologies to Mark as he is not dead (LateGreatU2) and it should have been LateBrakeU2.
Old 09-09-2008, 02:57 AM
CC Rider's Avatar
CC Rider CC Rider is offline
Wow, all of that from a stock appearing Chevelle. Very impressive.
Rick
1966 Chevy Caprice 427-390
