Old 08-27-2008, 05:56 PM
Johnny Horsepower Johnny Horsepower is offline
Default Re: Diverter Valve Rebuild Source Needed,... I Thi
The system is stock with full functioning smog pump with the guts intact. I routed the 1/4 inch hose from the back of the diverter valve to the side nipple on the side of the quadrajet carb on the passenger side. The kit also came with a white "T" but I didn't know where that went. There is also a 1/4 hose that runs from the back of the intake to the distributor vacuum advance. Should I "T" off of that?
As to when it makes the back-fire/ popping noises, my car is a 4sp and when I wind out first and shift to second I hear the noise. Also if I'm going down a steep hill and coast in gear at speed down the hill I hear it as well.
I had the EXACT same issue with my 70 Z28 4spd. I tried timing etc. In the end we put it on the dyno, and tried some things. Here is what worked. Freeze plugs on both sides of the air unit.
Has been running great ever since.
John
Old 09-20-2008, 07:44 PM
'69Novajoe's Avatar
'69Novajoe '69Novajoe is offline
I remember having this problem on the Nova. And like Rick (mr70) mentioned, the vacuum hookup was my problem. Make sure it is manifold vacuum. I had switched the vacuum advance line with the diverter line. Problem solved!!
Joe
I ain't as good as I once was, but I'm as good once as I ever was.
Old 09-20-2008, 08:59 PM
JIM, May we SEE pictures of your divertor valve work and be quoted a price and contact info.
I have at least one 297 & 295 that need cosmetic and mechanical (???) attention.
Chuck Sharin
[email protected]
69 Camaro COPO "recreation"
