Old 08-09-2008, 05:02 PM
Default Re: th400 converter help
Add washers or shims.
Paul
Old 08-09-2008, 06:33 PM
Dusk Blue Z Dusk Blue Z is offline
The only time I ever had to shim one was when using a mid mount motor plate. If you shim too much you will lose the support of the fit between the nose of the converter and crankshaft. 1/4" sound fine to me.
Mike
Old 08-09-2008, 07:43 PM
So if you shim or use washers between the flexplate and the converter tabs would standard flat washers do or would a special material be needed??????
Carl
Old 08-09-2008, 09:34 PM
scuncio's Avatar
scuncio scuncio is online now
Use parallel ground washers. The flexplate to converter lug surfaces need to be tightly controlled to prevent misalignment of the converter snout into the trans.
Old 08-10-2008, 10:15 PM
10/4 thanks for the help guys!!!!!!!!!!!!
Carl
