Old 07-29-2008, 06:31 AM
68-69-70Nova SSL78 68-69-70Nova SSL78 is offline
Default Re: Need advice on new ZL1 engine
I was going to put it in my 55 chevy (with straight axle) but since the engine was very late to come out I opted for a 327 a just drive the car on the street all the summer. I have to say it's been a gas ser. No pun intened. And a small block to run around town works fine. So the ZL1 engine would for the time be just an investment. But I like the idea of #1 or #427 that might be the only 28K investment. Thats probably out of the question but I'll call my chevy dealer to see if thats possible.
Thanks you all that have given advice. Ed
Old 08-06-2008, 09:36 PM
69SSZL1's Avatar
69SSZL1 69SSZL1 is offline
Theres one on Ebay now, $24,995
http://cgi.ebay.com/ebaymotors/ZL1-427ci...1QQcmdZViewItem
Old 08-06-2008, 09:59 PM
PeteLeathersac's Avatar
Cool piece...but $25 thou.?.
Here's some published specs and Dyno #'s below..
~ Pete
Anniversary Edition 427 Tech Specs:
Engine Type - Aluminum Chevy big-block V-8
Displacement - 427 cu in
Bore x Stroke - 4.25 x 3.76
Block - Cast aluminum with 4-bolt main caps
Crankshaft - Forged steel
Connecting Rods - Forged Steel
Pistons - Forged Aluminum
Camshaft Type - Hydraulic roller
Valve Lift - .510 intake / .540 exhaust
Camshaft Duration (@.050 in) - 211° intake / 230° exhaust
Cylinder Heads - Aluminum oval port, 110cc chambers
Valve Size - 2.19 intake / 1.88 exhaust
Compression Ratio - 10.1:1
Rocker Arms - Aluminum roller style
Rocker Arm Ratio - 1.7:1
Distributor - HEI type
Carburetor - 870-cfm
Water Pump - Aluminum short style
Spark Plugs and Wires - included
Flexplate - 14"
Recommended Fuel - 92 octane
Ignition Timing - Base 8° BTDC, 36° Total
Maximum Recommended RPM - 6000
Balanced - Internal
Dyno Numbers
427ci ZL1 Crate Motor
RPM TQ HP
3,100 460 271
3,200 461 281
3,300 470 295
3,400 478 309
3,500 481 320
3,600 483 331
3,700 484 341
3,800 484 350
3,900 483 358
4,000 480 366
4,100 477 372
4,200 473 378
4,300 470 385
4,400 469 393
4,500 468 401
4,600 467 409
4,700 466 417
4,800 464 424
4,900 461 424
5,000 461 430
5,100 457 435
5,200 453 440
5,300 449 445
5,400 445 449
5,500 441 453
5,600 436 457
5,700 431 459
5,800 424 460
5,900 408 458
6,000 394 451
