Old 05-16-2025, 12:39 AM
NorCam's Avatar
NorCam NorCam is offline
I ran a low compression pump gas 565 Dart Big M in my last 55 Chev that made 732/713 with a T56 in behind it. Out back was a mini tubbed 4 link 9" and the car was tied in with an 8 point cage which helped stiffen it up. Fun street car that ran through the gears in OK fashion if you were banging on it...but clearly, the trans didn't like the power. I had to modify the tunnel for that case to fit too, and now that I am building another 55 with a little less power, I have gone with the TKX 5-speed which really is the best of best from what Jody Haag told me.
Rows like a 4 gear when you just want to cruise, but can bang gears better than the T56 while standing up to about 700hp with no problem. I'll have this one on the road real soon and can't wait to try it out. Running a McLeod hydraulic clutch on this one and a Quick Time bell housing.
The Following 6 Users Say Thank You to NorCam For This Useful Post:
cheveslakr (05-16-2025), Chuck_Burg (05-16-2025), dykstra (05-16-2025), PeteLeathersac (05-16-2025), RPOLS3 (05-16-2025), SPEEDYB (08-07-2025)
  #182
Old 08-06-2025, 05:49 PM
napa68's Avatar
napa68 napa68 is offline
After getting all of the Corvette distractions behind me (at least for now), I can get back on the Nova. While the runaway temp issue had improved, it still was not right. After consulting with a few different people as well as some internet sleuthing, I decided on installing steam vent lines / 4 corner cooling through the intake manifold. As mentioned before, the siamese bore blocks can be a little tricky to cool, to say nothing for getting the air bled out properly.
So, I tore into it. Pulling the intake, drilling the rear on the intake for pipe threads, installing the fittings, and then piping the hoses to the front of the intake. I also installed a spacer between the intake and thermostat housing to relocate the temp sender. Additionally, I drilled a small relief / bleed hole in the 160 degree T stat to help with bleeding the air.
The cooling system bled out easily, and maintains 180 degrees in the shop with no real air flow.
Of course, no good project is considered complete without a road test.....
I am happy to report the car maintains 160-170 degrees on the road, will creep up to 180 at a stop sign. In all, a success!
The Following 16 Users Say Thank You to napa68 For This Useful Post:
'69Novajoe (11-08-2025), 69M22Z (08-07-2025), Arrowsmith (08-06-2025), big gear head (08-07-2025), dykstra (08-06-2025), gtomike1967 (08-06-2025), Hawkeye (08-06-2025), L78_Nova (08-06-2025), olredalert (08-06-2025), PeteLeathersac (08-07-2025), Roger M (08-06-2025), RPOLS3 (08-06-2025), SPEEDYB (08-08-2025), Tenney (08-07-2025), Too Many Projects (08-06-2025), Xplantdad (08-06-2025)
  #183
Old 08-06-2025, 06:13 PM
RPOLS3's Avatar
RPOLS3 RPOLS3 is offline
Excellent
Jake Dykstra
Dykstra Motorsports
The Following User Says Thank You to RPOLS3 For This Useful Post:
napa68 (08-06-2025)
  #184
Old 08-06-2025, 06:19 PM
TimG TimG is offline
Now let's see you overheat the tires........
The Following 7 Users Say Thank You to TimG For This Useful Post:
67since67 (08-06-2025), big gear head (08-07-2025), dykstra (08-06-2025), L78_Nova (08-06-2025), napa68 (08-06-2025), PeteLeathersac (08-07-2025), RPOLS3 (08-06-2025)
  #185
Old 08-06-2025, 08:08 PM
RPOLS3's Avatar
Maybe we need to get Charley to get behind the wheel for some video......
Jake Dykstra
Dykstra Motorsports
dykstra (08-06-2025), olredalert (08-06-2025)
  #186
Old 08-06-2025, 11:36 PM
Awesome! Can I steal your idea Tim? I have another potentially worse problem child in the works
The Following 4 Users Say Thank You to Arrowsmith For This Useful Post:
dykstra (08-07-2025), napa68 (08-07-2025), PeteLeathersac (08-07-2025), Xplantdad (08-07-2025)
  #187
Old 08-07-2025, 01:10 AM
napa68's Avatar
Oh....do tell more!
Old 08-07-2025, 11:23 AM
Smile
Originally Posted by napa68 View Post
Oh....do tell more!
Just my Corvette: Siamese bore block + low aluminum rad height with remote expansion tank looks like it will be grumpy. But I really don't want to mess up your thread with my junk Tim . You did a great job working out the fix. Wonderful workmanship too. Love it. W
The Following 2 Users Say Thank You to Arrowsmith For This Useful Post:
napa68 (08-07-2025), Xplantdad (08-07-2025)
  #189
Old 08-07-2025, 11:56 AM
napa68's Avatar
Besides the steam lines and T stat hole, I vacuumed the system, and had the front end elevated considerably while filling as well. Would love to see the updates on your new project. For as silly as this car is under power, I can only imagine what your Corvette will be like........
The Following 2 Users Say Thank You to napa68 For This Useful Post:
Arrowsmith (08-07-2025), Xplantdad (08-07-2025)
  #190
Old 08-07-2025, 01:08 PM
napa68's Avatar
The Canadian wild fires are at least good for one thing around here, it helps with the lighting for photography. Here are a few from shots I took this morning
'69Novajoe (08-07-2025), 69M22Z (08-07-2025), Arrowsmith (08-07-2025), big gear head (08-08-2025), Chuck_Burg (08-07-2025), dykstra (08-07-2025), earntaz (08-08-2025), L78_Nova (08-07-2025), ls6owner (08-07-2025), PeteLeathersac (08-08-2025), Pro Stock John (08-07-2025), ragtop (08-07-2025), RPO LS7 (08-07-2025), RPOLS3 (08-11-2025), Tenney (08-07-2025), Too Many Projects (08-07-2025)
