Go Back   The Supercar Registry > Comments/Suggestions > Comments, Suggestions, Problems
Old 03-09-2017, 01:06 AM
PeteLeathersac's Avatar
Thanks Jody and I think that's what I did but will have to give it another go.
Is there any way to capture picture file names once uploaded now?
With the old system, you could upload a few then arrange their order by cutting/pasting or easier was just swapping the last digits of file names.
I have a bunch o' pics saved I had previously uploaded to the old system but can't see their file names now?
Looks like I can maybe "quote" them into threads but would appreciate learning better ways to manipulate files etc.
~ PETE
Old 03-09-2017, 01:48 AM
camcojb's Avatar
camcojb camcojb is offline
Administrator
~ PETE
If you right click on the picture it will give you the web address and pic name.
Jody
Old 03-09-2017, 03:43 AM
Kurt S Kurt S is offline
In the Default theme, a section will indicate that there is an unread thread. But when I view the topics, none are highlighted as unread. Doesn't happen all the time.
Not a problem in the Yenko theme.
Strange....
Not sure if it's possible, but instead of just the little picture being different to show that there is an unread thread in a section, can the title of the section also be bolded?
Thanks!
Kurt S - CRG
Old 03-09-2017, 05:25 AM
RST's Avatar
RST RST is offline
Originally Posted by camcojb View Post
I switched the default setting to be "default" instead of the Yenkotheme that was built. Seems far more people prefer the default look. We're going to switch the colors and add the logo and vendor banners, but keep the default framework.
You can still view the Yenkotheme if preferred, just switch it in your user cp options, or at the bottom left of the forum page.
Yes, I like the default much better Thank you!! I cant get my signature picture to post? thank you very much for all the hard work.
RST
1968 1/2 Cougar 428 R Code, Cobra Jet, 4 SPD, Red Interior in restoration at MASCAR to be unveiled by Kevin Marti at the MCACN 2020
1970 Top Secret Very Special Muscle Car in restoration by MASCAR to be unveiled at MCACN 2020
Old 03-09-2017, 05:29 AM
One more thing about sections.
If I go into the Tech section and read the new posts and return to the index, refreshing the index does not change the status of the Tech section. It still shows unread topics, which isn't true.
This is a pain, because sometimes I can't remember which sections I've looked at, and the forum won't accurately tell me.
Kurt S - CRG
Old 03-09-2017, 11:04 AM
Is anyone else noticing this?
I logged on to see I have 745 in box messages and am full.I was full prior to this change over,but now each conversation is broken down into single separate individual replies.
Meaning if I had a conversation with someone prior to the new change containing 15 bundled replies back & forth between us,I now have 15 individual Private Messages for each reply showing for that 1 single conversation today.
Is this the new norm?
Old 03-09-2017, 11:34 AM
m22mike's Avatar
m22mike m22mike is offline
Default posting
Pic#1, When I post or load a photo I never see this screen as in Bruces example above.
Pic #2, This is what I see. Do I need to change a setting ?
Old 03-09-2017, 02:53 PM
70 Forest Green Zee's Avatar
70 Forest Green Zee 70 Forest Green Zee is offline
Mike....here's what you need to change to get the screen you're looking for.....
go to user CP
Edit Options
scroll down to the last section Miscellaneous Options
Message Editor Interface
Change this setting to "Enhanced Interface- Full WYSIWYG Editing"
You'll then have the screen you're looking for with all the Yenko icons from the old software
hope this helps
1970Camaro Z28
Old 03-09-2017, 03:25 PM
m22mike's Avatar
That worked, thanks.
Mike
Old 03-09-2017, 04:22 PM
camcojb's Avatar
Administrator
We are doing some custom code changes, and conversations for pm's is one of them. Should have a lot of this stuff done in the next week or two.
Jody
