Old 09-12-2016, 12:20 AM
Ryan1969Chevelle's Avatar
Running sounds real good!!!
Ryan
PS: Dave Siltman suggested I get the adjustable clutch fork stud so I can set up the linkage perfectly.
Old 09-12-2016, 01:47 AM
Dave always has great suggestions [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
Old 09-13-2016, 03:45 AM
junior supercar junior supercar is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Ryan1969Chevelle</div><div class="ubbcode-body">Brand new normal u joints with grease fittings.....
Lakewood u joints? Do they fit the standard yokes?
Ryan </div></div>
yep. running them in both the 31 and the 37.
1969 Cutlass S W-31 - 13.86@100 TnT US41 2009
1970 Tempest GT-37 400ci 4bbl 4sp - [email protected] PSMCDR 2011
1970 F-85 - daily driver or clock it with a sun dial
plus others
Old 09-13-2016, 01:00 PM
Lakewood Suspension 23011 - Lakewood Performance U-Joints
Is this the right part number?
Both the same?
Ryan
Old 09-15-2016, 05:45 PM
Is this flywheel an 11 inch or 10.5?
Is my clutch assy 10.5?
Will an 10.5 or 11&quot; fit in this blow up proof bell housing Lakewood 15100?
Ryan
Old 09-15-2016, 09:34 PM
Yes, it will fit......carry on [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
Old 09-16-2016, 04:02 AM
I need a little more than that:-)
CU in the morning at PSMCDR!!! I will get the full story
Ryan
Does an 10.5 pressure plate bolt to an 11 inch flywheel?
Old 09-16-2016, 04:57 AM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Ryan1969Chevelle</div><div class="ubbcode-body">I need a little more than that:-)
Ryan
Does an 10.5 pressure plate bolt to an 11 inch flywheel? </div></div>
Do I ever give you 1/2 of the story [img]<<GRAEMLIN_URL>>/naughty.gif[/img]
Old 09-16-2016, 12:02 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Postsedan</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Ryan1969Chevelle</div><div class="ubbcode-body">I need a little more than that:-)
Ryan
Dan </div></div>
That is not my point at all, my point is I am about the spend hundreds and hundreds of US dollars and I am freaking out that I will buy some parts that don't work together.
I need a clutch chat to put me at ease about buying these items.
Ryan
Old 09-16-2016, 12:58 PM
DW31S's Avatar
DW31S DW31S is offline
Wow!!! I WISH I only spent hundreds and hundreds!!!
Listen to us Grasshopper, we won't steer you in the wrong direction.
