Old 08-22-2016, 12:26 AM
Ryan1969Chevelle's Avatar
Here are the pictures of the Hurst RamRod Shifter rebuild:-)
While you are at it Nick..... may as well do two shifters at the same time:-)
Ryan
Old 08-22-2016, 02:01 AM
junior supercar junior supercar is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Postsedan</div><div class="ubbcode-body">Smart.....before you put the new motor in [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
Dan </div></div>
actually I've been trying for years to get her to drive the car with the new motor. always an excuse. [img]<<GRAEMLIN_URL>>/hmmm.gif[/img]
1969 Cutlass S W-31 - 13.86@100 TnT US41 2009
1970 Tempest GT-37 400ci 4bbl 4sp - [email protected] PSMCDR 2011
1970 F-85 - daily driver or clock it with a sun dial
plus others
Old 08-22-2016, 09:31 PM
I called the engine machine shop after work for an update.
The original cylinder heads are scrap (as I already knew but wanted a second opinion)
The extra engine heads checked out good with MPI.
The extra block checked good with MPI.
The extra crank is scrap, I have to see it (so I will drop off my warranty W31 short block to hopefully donate the crank)
I will stop by this week to take scrap home and drop off, and to take pictures:-)
I am curious to see the bores measured to see if we can stay at 0.030&quot; with honing only? This will save the cost of boring which will allow for a few unseen costs.
Ryan
Old 08-22-2016, 09:54 PM
69 Post Sedan's Avatar
Did they say why the parts were scrap.....specifically the heads?
1968 Schwinn Orange Krate
1969 Schwinn Pea Picker
1968 Schwinn 5-Speed
1970 Schwinn 3-Speed Deluxe
1973 Schwinn 5-Speed Suburban
All Original Paint Bikes
Old 08-23-2016, 01:14 AM
I am going after work tomorrow to inspect, and discuss.
A few of the combustion chambers are rusted badly, really deep pitting, a few ports are rusted bad, a few valves are broken off, a few studs are broken off..... Very bad set of heads, I may media blast them to make good wall art.
Ryan
PS: I got my warranty W31 from the engine stand to my car by myself:-) also packed up the flywheel for machining/balancing.
Old 08-23-2016, 02:57 AM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Ryan1969Chevelle</div><div class="ubbcode-body"> Very bad set of heads, I may media blast them to make good wall art.
Ryan
PS: I got my warranty W31 from the engine stand to my car by myself:-) also packed up the flywheel for machining/balancing. </div></div>
very bad, thats giving them to much credit. Try evaporust instead of media blasting.
if you plan to race, might I suggest a centerforce flywheel. Your right foot will thank you.
plus others
Old 08-23-2016, 10:01 AM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: junior supercar</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Ryan1969Chevelle</div><div class="ubbcode-body"> Very bad set of heads, I may media blast them to make good wall art.
Ryan
if you plan to race, might I suggest a centerforce flywheel. Your right foot will thank you. </div></div>
I will look into the flywheel, do you know of a specific model?
Ryan
Old 08-23-2016, 12:13 PM
Ready to go:-)
Ryan
Old 08-24-2016, 01:40 PM
What is wrong with the &quot;scrap&quot; crank did not take a long time to understand:-( Wiped right out.
Al and his daughter had bought this engine used, and installed it in an attempt to resurrect the car, it probably would have ran for a while but the bearings would have soon spun and seized the rotating assy.
I hope the crank is good from the warranty short block.....
I only had a few minutes to drop off items and check out the crank and vacate the dance floor.
I did look on Summit for better quality flywheels....... I didn't have this in the budget........... more research required, possibly source a used piece and have it reworked and balanced?
Ryan
Old 08-24-2016, 06:01 PM
I'm running a stock 3/8&quot; connecting rods, cast iron crank and flywheel, shifting at 7000 rpm. I will go out on a limb and say you probably won't abuse your car as hard as I do. [img]<<GRAEMLIN_URL>>/scholar.gif[/img]
In other words.......if the motor is built/balanced correctly, you really shouldn't have an issue......but never say never as the old saying goes.
Kurt
