Old 07-19-2016, 04:57 PM
Ryan1969Chevelle's Avatar
I will just use the manifolds I have without the heat riser, nobody is judging this old girl:-)
Ryan
Old 07-19-2016, 05:24 PM
Update:
So I made a final decision and loaded up my extra engine to be rebuilt. This was a huge step for me, I have considered all options, researched costs, visited several builders, received several quotes verbal and paper, read forums, posted on CO for support, and many Olds people have shared information, ideas, supplier contact info, phone calls, emails, PM's, posts, you name it. Thanks to all who have taken the time to help me move in the right direction.
I have used names as I have visited various engine builders maybe this is right, maybe this is wrong...... TBD, each person I visited in my opinion would have been a perfect candidate for my rebuild but I only get to pick one builder. I am thinking I will keep names out of this for now and share a huge thank you at the end with business name and contact information if I am a satisfied customer. (I have every indication this will be the case or I would not be moving forward)
As I am not painting the car, the engine is the biggest/most expensive item on the punch list.... This is very stressful for me, I also honestly feel quite guilty moving forward with such an expense, just for ME. (I shared my mini vintage trailer idea with "Beautiful, Olds Loving Wife" and she loves the idea so this won't be just for ME)
I used the incline plane, and rolled the short block right up into the car, used a spare tire and wood blocks to support it:-) Felt a little proud:-)
I am sending the original heads as well as the "extra" engine heads. I hope they can save the original heads, but I am quite confident they are space junk/wall art.
I am dropping off both intakes, probably prep both while we are at it:-)
Ryan
Old 07-19-2016, 05:39 PM
Rixls6 Rixls6 is offline
Glad to see you make the jump with your engine.
Bet you can't wait to hear it run on a dyno.
Love the line &quot;felt a little proud&quot; in regard to ramping the engine into the car. [img]<<GRAEMLIN_URL>>/grin.gif[/img]
Rick
Don't text and drive.
Old 07-19-2016, 06:26 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Rixls6</div><div class="ubbcode-body">Glad to see you make the jump with your engine.
Love the line &quot;felt a little proud&quot; in regard to ramping the engine into the car. [img]<<GRAEMLIN_URL>>/grin.gif[/img] </div></div>
Thanks Rick!!
Had to order the &quot;Dyno Delete&quot; option RPO NO-Dyno:-( I have all the money assigned and then some so I had to ease off on several items to stay on budget. This was one of the reasons I sent my distributor and carburetor to Dan Jensen so I can lean on him a little for butt-dyno tuning tips at PSMCDR. (He will already know all my details)
This engine shop runs the engine with an electric motor on a stand to verify oil pressure, flow to all visible locations, no-leaks, and cranking compression for all cylinders.
Someday I could use a chassis dyno to do some testing a friend has a car show in town each year and this year he had a chassis dyno for runs all day, this may be an option. I dislike the idea of a chassis dyno as there are so many safety risks.
Ryan
Old 07-19-2016, 09:55 PM
Engine has been handed off:-)
I don't like the stuff I can't control:-)
Ryan
Old 07-19-2016, 10:25 PM
Stressed? This is fun....the stress will start if or when the engine happens to go south.....just say`n as it does happen often...depending on your right foot.
I have made many mistakes on my own personal builds.....if I could do anything over again....I would gladly pay to have my engines dyno-ed.....learn from us my friend.
Old 07-20-2016, 12:13 AM
I appreciate the comment but the costs as far as I have seen are 500 to 1000 per day, and in some cases this is just to run the dyno, you tune as you wish.
If a situation arises that I can dyno I will but to pay straight up for a tuner and the dyno day is not realistic.
Regular guy here:-)
I have a budget to get an exhaust gas temp sensing unit, mainly to prevent lean situations.
Ryan
Old 07-21-2016, 01:02 AM
69 Post Sedan's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Ryan1969Chevelle</div><div class="ubbcode-body">I appreciate the comment but the costs as far as I have seen are 500 to 1000 per day, and in some cases this is just to run the dyno, you tune as you wish.
Regular guy here:-)
Ryan </div></div>
$500-$1000 WOW!!!......I sure wished you lived closer to me Ryan as my engine builder, Gary Soderberg at SRL Motorsports charges $250 for 4 pulls and I think $350 will get your carb tuned to your motor.
Having it run on a test stand is still a great idea as you don't want to go through all the hassle of dropping it in the car then have issues.
Kurt
1968 Schwinn Orange Krate
1969 Schwinn Pea Picker
1968 Schwinn 5-Speed
1970 Schwinn 3-Speed Deluxe
1973 Schwinn 5-Speed Suburban
All Original Paint Bikes
Old 07-21-2016, 03:17 AM
junior supercar junior supercar is offline
my dyno time for the 400 poncho in my GT-37, about $800 for like 19 dyno pulls, which included cam break in, tuning carb, timing and other things. it was basically most of the day on the dyno. Money VERY WELL spent. zero issues after install and many a smokey burnout and drag strip passes
I wouldn't even think of not dyno'ing my W-31 build as I've already made plans for it
1969 Cutlass S W-31 - 13.86@100 TnT US41 2009
1970 Tempest GT-37 400ci 4bbl 4sp - [email protected] PSMCDR 2011
1970 F-85 - daily driver or clock it with a sun dial
plus others
Old 07-20-2016, 02:47 PM
Fingers crossed:-)
That would be a record, based on all feedback on the interweb.
Chickens are not hatched, no counting will occur till such time.
Ryan
