Old 06-04-2004, 02:13 AM
Default Re: General LT-1 Information
I'm picking up the heads tonight, no 'cheatin' done to them, just getting them relooked at while I had the engine down for the cam swap.
I originally installed a Comp Cams with a little more lift, and a little less duration, but with a lot less 'overlap' in an effort to increase cylinder pressure and therefore bottom end torque. After learning a little more about cams from Pete, Rob and others, I realized that this cam was not what I really wanted, and that the stock cam is the best. So, I tore it down, and found some other issues to straighten out, (like a little valve cover oil leak, cracked oil sending switch, etc...) but now am in the rebuilding stage.
Anyone want to suggest the easiest way to degree a cam, without buying the whole degree kit?
Old 06-04-2004, 03:03 AM
Isn't there cam bottons made? I think they have different degrees in them like 3 degress advanced and so. I would call Crane and ask them what they advise, Maybe put it in straight up. Line the marks up. I would make a call though. Going to see you at Lansdale: (Under The Lights) Same weekend as GM Carlisle. Sat. nite Sam
Old 06-04-2004, 05:55 AM
JoeG JoeG is offline
Sam is right call crane --it will save you a lot of trial work---
Old 06-04-2004, 04:34 PM
Casey Marks Casey Marks is offline
.....no 'cheatin' done to them, just getting them relooked at while I had the engine down for the cam swap....
Uh huh ...... that's what they all say ......
Old 06-04-2004, 05:15 PM
Casey, you must have a guilty conscience.
Old 06-04-2004, 05:44 PM
They told me if I wore the dress and the high heels, they'd pay me $100. I was young back then, and needed the money.....
....oh wait, you're not talking about that ........
Old 06-04-2004, 06:03 PM
We told you,we left your money on the Nightstand Casey!
Old 06-15-2004, 09:31 AM
hvychev hvychev is offline
Just get that car back together Marlin......you have an obligation to meet on Labor Day weekend...if you don't show I will just assume that you forefitted and are scared.....
Frank Magallon
Old 06-16-2004, 12:05 AM
I'm workin on it! The heads are back on, the Crane Blueprint cam is in, lifters and pushrods, along with the timing chain and gears. I hope to have the chain cover on, water pump and the intake installed, and the valves adjusted by the weekend. Then, it's the small stuff!
Old 06-16-2004, 12:08 AM
Chevy454 Chevy454 is offline
Good to hear, M!
