Old 09-15-2015, 12:46 AM
Default Re: Gramma's Car: the new project!
Steve,
I don't comment on your threads enough but I am always following them. Well done. I love plasti gauge. Such an easy way to check the machine shop. Your offspring are going to be some of the few who still know how to build a vintage engine in years to come. I plan to pass the touch as well.
Currently in training:
n
Old 09-15-2015, 01:00 AM
Nice pirate hoard of parts!
My son was at the kitchen table a few minutes ago and was doing his history homework. The assignment involved interviewing someone about an event in the past. He picked the prior engine rebuild of Gramma's car from 2011. It seems that I remember a lot more than he does, about events four years in the past when he was ten years old. [img]<<GRAEMLIN_URL>>/smile.gif[/img]
Old 09-15-2015, 01:31 AM
That's awesome Steve. I hope you don't feel like I was trying to hijack your thread. I just thought it was a decent parallel. Again, great job on the build and family.
Old 09-15-2015, 02:52 AM
No problem. Loved the photo. [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
Old 09-15-2015, 03:23 AM
earntaz earntaz is offline
Will not Plastigage give a more accurate measurement on a dry surface -- no oil or Lubriplate? TAZ
Old 09-15-2015, 03:37 AM
The actual area where the plastigage was placed is clean, though it's hard to tell in the photo. I wiped the application area clean of oil and lubriplate prior to the application of the plastigage and retorquing the main cap. After taking the measurement I then clean the plastigage off with a little brake clean and then reapply the lubriplate prior to reinstalling the main cap and torquing to spec.
Old 09-15-2015, 12:49 PM
cook_dw's Avatar
cook_dw cook_dw is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: njsteve</div><div class="ubbcode-body">I then clean the plastigage off with a little brake clean and then reapply the lubriplate prior to reinstalling the main cap and torquing to spec. </div></div>
Most people dont realize that leaving any of the plastigage on the bearing surface can cause a premature failure.. [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
Old 09-18-2015, 12:54 AM
I sent that 1971 7041262 455 Quadrajet to Eric (Vintage Musclecar Parts) for some magic. Let's see what he does with it. [img]<<GRAEMLIN_URL>>/naughty.gif[/img]
Old 09-18-2015, 06:34 PM
VintageMusclecar's Avatar
Last month Steve approached me about building a Quadrajet for this project. Of course I enthusiastically agreed!
The carb arrived Wednesday. Nice packaging job Steve! [img]<<GRAEMLIN_URL>>/grin.gif[/img]
I got the carb out of the box and immediately two things jumped out at me. See if you can guess the first one:
Look closer...
Somewhere along the line, a ham-fisted &quot;mechanic&quot; has cranked this poor carb down to an intake with everything they had.
Can you see the resulting bow?
Look at the gaps at the end of the straight-edge:
And in the center of the top casting here:
I've seen a LOT worse, but this one still requires de-warping.
Now that the lid is off (not w/o a struggle, be back to that in just a moment), we can see she's nice and crusty inside.
Here's the next clue something was amiss:
Not an OEM fuel inlet fitting...that usually means....
Yep...a self-tapper. Someone's stripped the inlet threads at some point. Nothing we can't handle though.
As I alluded to above, the carb didn't want to come apart w/o a fight. It usually takes me ~45 minutes to break a Quadrajet down. I fought this one for over 2 hrs and <span style="font-style: italic">still</span> lost a couple of battles along the way lol.
One of these things is not like the other...
Both of them were stuck tight....with a lott'a heat and some penetrating oil I got one to break free, but the other wasn't having any part of it.
Lousy little....&amp;*@^*^!^$
I tried heat &amp; Vice Grips, again to no avail--broke off flush, so I had to drill the remnants out from the backside.
SO...the carb's 99% disassembled at this point, and the main body is currently cooling down on my de-warp fixture. Once it's done I'll de-warp the top casting, then it's back to the main body to remove the idle pick-up tubes. I don't normally remove the idle tubes when servicing a Quadrajet, but when one's this crusty inside, they really need to come out to make sure there's no corrosion in the main well and/or on the tubes themselves that could cause problems later on down the road.
More soon, stay tuned.
And before I forget, thank you Steve for letting me be a part of this build. [img]<<GRAEMLIN_URL>>/beers.gif[/img]
Old 09-18-2015, 06:48 PM
Wow, you do some amazing work. If I'm ever in the position of having one (or two) carbs rebuilt, you're the go-to guy.
John 10:30
