Old 06-08-2016, 01:17 PM
Ryan1969Chevelle's Avatar
I got all excited last night and after the usually run a round, diner this, practice that, I snuck out to the garage and stayed out till 11:00 PM:-)
I boxed up any labeled baggies from my container shelf as either items that I have already replaced, or as items that will be replaced shortly, this way I don't have to dig through everything to look at a fastener, or a clip.
Then I started making labeled baggies of item off my extra engine. (This engine was bought used and installed by Al and his daughter at her high school, so it has the original accessories installed on it) This extra engine is not a W31, as you can see dished pistons, regular harmonic damper, small valves in the heads, etc, but the accessories are gold!!
I am getting my original front upper control arm washers coated, and noticed they are two different sizes, does the big one go to the front?
Ready to disassemble
Ignition hold down, this is an HEI, yuk
Alternator brackets
Ryan
Old 06-08-2016, 01:23 PM
Original alternator. (I remember checking the numbers a while back)
Original fuel pump (checked numbers in the pink charts in my assembly manual)
I will check for numbers as I gently clean the fan, I think it is to have a U0 stamp?
Original pulley KA:-)
Ryan
Old 06-08-2016, 04:46 PM
I need to figure out if this is off the extra engine or original
KB Crank Pulley
Again, need to check if this is original? (I could tell by all the damage that it was taken out at one time:-(
4 speed specific item to route the positive battery cable.
Intake
Water pump
Ryan
Old 06-08-2016, 04:52 PM
Now the meat and potatoes:-)
Dished pistons, but condition is good, small valves, but condition is good:-)
Al bought this as a running engine "with a cam" half the head bolts were stinging tight and half were finger tight, some were painted and some were not so the heads were off before he bought it or during the installation a few high schoolers forgot to use the pattern to torque?
All the rockers, and bolts, and pushrods, looked very good, just some surfaces with a tiny bit of wear in the normal locations such as in the bottom of the rockers. All even and all good.
Old 06-09-2016, 10:43 AM
I spent some time in the garage last night:-)
Removed the:
Water pump
Harmonic damper
Timing cover
Oil pan
And one piston and rod
Found the bottom end to be clean, rotate freely, and has been rebuilt previously. The Pistons are 0.030" over and the timing chain is a dual roller.
I was happy with what I have seen so far, looks like a fine candidate for rebuild and use.
Spent a good deal of time cleaning up oil off the floor, I couldn't drain the pan easily and missed the tray I prepared:-(
I will contact the machinist to see what dimensions I should check before disassembly, I took a middle piston out so I can check piston to deck height at all four corners, I also plan to check end play at the thrust bearing.
Ryan
Old 06-09-2016, 12:35 PM
earntaz earntaz is offline
Just a suggestion -- if the .030 out bore will not clean up or out of tolerance you may want to go to .040 out. Your machine shop can hone to that instead of boring to say .060. Also, if something were to "happen" you still have room to bore further. TAZ
Old 06-09-2016, 01:14 PM
DW31S's Avatar
DW31S DW31S is offline
Good suggestion. Oldsmobile stuff isn't as readily available as other brands, so "saving" a good '69 vintage block is a wise thing to do.
Old 06-09-2016, 02:22 PM
Thanks for the suggestion.
0.040" would leave one more boring for future. (My the "interweb" I have read many accounts of sonic checking and boring 350 Olds up to 0.125" without issue so 0.060"-0.070" should be no problem next time.
Ryan
Old 06-09-2016, 02:40 PM
More engine disassembly pics.
Lifters looked new
This is the bottom end of my W31 Warranty short block, I think the timing chain is the original style?
Old 06-09-2016, 02:42 PM
More pics
