Old 02-12-2019, 12:34 PM
big gear head's Avatar
That's going to be awesome. This is going to be such a great car when you are done.
Freddie
NorCam (02-12-2019)
Old 02-12-2019, 07:40 PM
NorCam's Avatar
NorCam NorCam is offline
Intake gaskets are set and I'm ready to mount the Crossram, but first comes the new gauges and a 90 degree fitting for the oil pressure gauge. Forgetting to install this BEFORE you install a Crossram intake will cause you some hardship. Ask me how I know this...lol. Anyway, added the 90 fitting to get the line connected and now I'll mount the lower base. Here's a few pics to update the thread.
Installing the oil fitting ahead of the lower base which overhangs the rear of the block.
You need a 90 fitting back here or the oil line won't fit under the rear lip of the intake as it overhangs the block.
New SW Green Classic Gauges mounted up under the dash.
Xplantdad (02-12-2019)
Old 02-12-2019, 10:29 PM
GrumpyJeff's Avatar
Im digging everything about this thing. I had my eye on that car for a little while before you got. Really neat Car, Great job Dude
Old 02-12-2019, 11:27 PM
NorCam's Avatar
Thanks Jeff. Appreciate that buddy.
Here's a few more pics as today continues on toward the finish line.
Lower base installed and torqued down.
Those would be some nice original M bolts I got from Sam Scardino
And those would be a super clean pair of original 4295 Crossram carbs.
Old 02-13-2019, 02:06 PM
cook_dw's Avatar
cook_dw cook_dw is offline
Looking really good. Don't forget to flip your valve covers!
The Following User Says Thank You to cook_dw For This Useful Post:
NorCam (02-13-2019)
Old 02-13-2019, 02:59 PM
NorCam's Avatar
Thanks Darrell.
Covers just got swapped around while put on as dust covers in those pictures. They'll be swapped around when installed.
First I have to mill down the side rails to they can come on an off properly.
Added
Just noticed they were also backwards on the run stand as well. I didn't even notice they went on like that at the machine shop and have been sitting there like that for months.
Old 02-13-2019, 03:29 PM
NorCam's Avatar
Was out in the shop last night trying to decide on what breathers to run. I can't fit velocity stacks under the stock hood and thought I'd see how the low profile crossram breather would look if I got the narrow base, but BLAH. I don't like all that elongated chrome atop this particular engine.
Quest is now on to find a pair of clean looking 9" filters. The K&N 60-1070 would fit the drivers side while the 60-1110 offers an inlet so I could add a vent hose from the passenger side valve cover? Gotta find something in the next few days or it's another rush air shipment from Summit. I'm trying to find something decent looking but options for 9" breathers are pretty limited. K&N has the best shaped tops but that embossed logo isn't period correct either. The hunt continues.
Old 02-13-2019, 03:34 PM
Locker537 Locker537 is offline
Could you color match the elongated chrome cover to the engine block / headers? That might give it quite the look...
Call me crazy, but you could always run the velocity stacks and no hood! Certainly fits with Day II to me!
Old 02-13-2019, 03:55 PM
NorCam's Avatar
Yes...no hood is definitely an option. Not a bad idea and your suggestion might just be the ticket for this one. Thanks Steve
Old 02-13-2019, 04:13 PM
outlawperformance outlawperformance is offline
I ran these cheapies from speedway with my stock SS hood they will fit. The rear carb I bent the lower flange down some and it didn't rub the hood at all. I'll look for a picture with the stock hood. I believe the stock breather with the thin element will work also I'm running the tall one now with the stinger hood.
The Following 3 Users Say Thank You to outlawperformance For This Useful Post:
Damien (02-13-2019), markinnaples (02-16-2019), NorCam (02-14-2019)
