Old 03-03-2015, 01:27 AM
69 Post Sedan's Avatar
Default Re: The Flying Dutchman 2014 New Thread!
I've heard you get about a 25-35hp gain from a vacuum pump.
Kurt
1968 Schwinn Orange Krate
1969 Schwinn Pea Picker
1968 Schwinn 5-Speed
1970 Schwinn 3-Speed Deluxe
1973 Schwinn 5-Speed Suburban
All Original Paint Bikes
Old 03-03-2015, 02:54 AM
Benny ain't tellin KB.
You will just have to line up next to him and see!
Old 03-04-2015, 12:37 AM
Ha......that would be fun running next to Benny.....well for only a short distance until he kicks in the secondary's.
Old 03-04-2015, 02:14 AM
No, no......... weight per cubic inch. You will get a couple lites on him.
Better not miss a shift though.
Old 03-04-2015, 11:53 AM
Not with the Ram Rod...... [img]<<GRAEMLIN_URL>>/[/img]
Old 03-04-2015, 02:59 PM
EZ Nova EZ Nova is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: 69 Post Sedan</div><div class="ubbcode-body">I've heard you get about a 25-35hp gain from a vacuum pump.
Kurt </div></div>
Theoretically this is true IF the motor was designed for it, OR is lacking and the pump can make up for this. IF engine has a smaller cam, you can create the vacuum as need there, therefore the Vac pump will do nothing really. AND too much vacuum can/will scavenge oil off rotating parts therefore loosing the film layer. NOT GOOD.
Buddy just built an LS 6.0 with small hyd roller. Made 585 Hp with 16 lbs of vac. So on this the vac pump might have cost Hp for the drive. Most I hear from want vac in the 18-22 lbs range AT RPM
'78 Z28 4sp being restored
'70 W30 convert TRIBUTE
'66 CANADIAN Nova SS Race Car
'69 FIREBIRD Tubbed Racecar
Old 03-04-2015, 07:48 PM
bbbenny bbbenny is offline
Running a vacuum pump is up to the guy owning the car. It;s a fact, keeping the crankcase in a vaccum. Will make the motor work eazier and keeps the oil from foaming in the pan. You can;t have too much vaccum, you will pull the oil off the rods and pins. I was told to only run 12 inches at full RPM. All I can say is i gained a whole 1/10 of a second and 3 plus MPH. Thanks The Dutchman [img]<<GRAEMLIN_URL>>/dunno.gif[/img]
Thanks Benny
Enjoy; orginal cars,with orginal drivetrains and docs. bblocks are my favorite.
Old 03-06-2015, 03:03 PM
Benny, YES some like yourself WILL pick up, other have not. Good that your running only 12 @ your RPM.
Your running well and consistent with you car, that's good. Just wondering how those heads are working out for you?
Old 03-15-2015, 11:55 AM
John, I;m running the same heads I had on the first motor. Strikeforce alum head. My engine guy said they work, good for the money. Nothing done no port or polishing. Bolt on and go! Thanks The Dutchman
Thanks Benny
Old 03-15-2015, 07:38 PM
Professor, YOU are a &quot;bolt on and go.&quot;
