Old 06-01-2016, 02:27 AM
Better to have a leak now than later.
Save that fluid. Did you use a gasket only? Gasket and RTV Sealant?
Lose the Gasket and only use Black RTV Sealant.....let it dry for a day and add gear oil.....through the fill plug!
Old 06-01-2016, 02:33 AM
Ryan1969Chevelle's Avatar
I like gaskets with no goop but if needed I will use the black RTV sealant.
The fill port is needed now, not removing the rear end to refill:-)
Thanks
Ryan
Agree nice to fix now vs later:-)
Old 06-01-2016, 02:39 AM
What you like.....will not fix it.
The fill plug was designed for a reason.....use it, my friend [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
Old 06-01-2016, 10:42 AM
I am picking up my Canadian made fuel tank after work:-)
I bought a Spectra W31 fuel system, tank, sending unit 3/8, with 1/4 return, and 3 line fuel pump, 3/8 inlet, 1/4 return, plus output line to carb. I even verified the pump output pressure as Eric on here warned of high pressure issues with some suppliers pumps. The great part is I bought these parts from a car guy (he is so excited about my build:-) at the local Ideal Supply/Napa so any issues are easy to deal with.
I will have him set out some black RTV (I very much dislike using sealants where they should not be needed but I dislike leaks much more) I Appretiate the recommendation as always Dan, just something I challenge regularly at work.
I have a trip planned soon to Wixom MI soon so I will switch out a few parts at InLine Tube otw. I accidentally bought a Chevelle pinion bumper instead of the rear end axle bumpers, and one outer tie rod is not correct, easy fixes and they are very accommodating with any requests. I am looking forward to visiting their facility.
I wish I had time to visit a few MI guys but we are going to MI and back same day..... Next time.
Ryan
Old 06-01-2016, 11:37 AM
I use Spectra Tanks in all my builds and I purchase them all through Napa. Here is another Tip,
Open and unwrap the gas tank when you are the Napa store - check the tank for any dents. I had two different occasions were two tanks had two very small dents, they obviously replaced the Tank.
We have a Ryan Weaver - crossing the border [img]<<GRAEMLIN_URL>>/naughty.gif[/img] Priceless!
Old 06-02-2016, 01:08 AM
napa68's Avatar
napa68 napa68 is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Postsedan</div><div class="ubbcode-body">I use Spectra Tanks in all my builds and I purchase them all through Napa. Here is another Tip,
</div></div>
great advice!
Old 06-01-2016, 04:45 PM
Note to self: check for dents.
Nice tip, that will save time later especially as these parts are going to be stored till I am ready to use them.
Ryan
Old 06-01-2016, 07:56 PM
Even parts in storage somehow acquire dents [img]<<GRAEMLIN_URL>>/no.gif[/img]
Old 06-01-2016, 08:19 PM
Or go missing, I haven't found my NOS posi tag yet:-(
Ryan
Old 06-01-2016, 09:41 PM
300deluxeL79's Avatar
300deluxeL79 300deluxeL79 is offline
buy another...then it'll turn up [img]<<GRAEMLIN_URL>>/rolleyes.gif[/img]
