Old 05-26-2016, 10:47 PM
L78racer L78racer is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Ryan1969Chevelle</div><div class="ubbcode-body">Who sells a good quality 4 speed transmission slip yoke? </div></div>
U-joints and yokes.
http://www.dynotechengineering.com/
Old 05-26-2016, 11:13 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Ryan1969Chevelle</div><div class="ubbcode-body">PS: INFO NEEDED:
What is a good quality pilot bushing? Good quality bronze, not steel covered in bronze looking coating.
What is a good quality throw out bearing to use?
Who sells a good quality clutch fork? Mine is damaged and welded and ground on the tips:-(
Who [email protected]ells a good quality 4 speed transmission slip yoke?
I have been using Inline Tube and Supercars Unlimited but looking for other suggestions.
Ryan
</div></div>
One word, one name - Crash
[email protected]
Old 05-28-2016, 05:06 PM
300deluxe 300deluxe is offline
I use roller pilot bearings, get them from Jegs or Summit
Old 05-28-2016, 09:54 PM
Ryan1969Chevelle's Avatar
Thanks guys, great advice!
Ryan
PS: I installed one coil spring this morning:-) I will post pics later.
It went very well, a few trials but all good.
The powder coating saved everything getting scratched to s###.
Old 05-28-2016, 09:59 PM
__________________________________________________ __
So true [img]<<GRAEMLIN_URL>>/headbang.gif[/img]
Old 05-29-2016, 01:21 AM
Damien Damien is offline
Great progress Ryan. Keep it going. [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
1969 SS 396/350 Chevelle
Old 05-29-2016, 03:56 PM
Passenger side coil spring install:-)
I media blasted my original shims and painted them, the inline tube shims don't really look like the originals:-(
It took a bit of trial and improvement to get the spring compressor located in the spring perfectly so I could compress the spring enough to install and yet still remove the compressor, and not interfere with the upper spring pocket, or lower control arm....... I took the pictures to try to replicate the set up for coil spring number 2:-)
My only issue was that the powder coating is slippery and the compressor spoon wanted to slip/rotate up the coil and the hooks wanted to slip/rotate down the coil. (If that makes sense?) (basically the compressor wanted to rotate on the axis of the coil spring instead of compressing the coil spring) so I added scotch brite for traction on all contact points and it did not slip at all after wards.
I wish I had time to do the driver CS today but lots of other fun stuff planned, only time to post a few pics and go.
Ryan
Old 05-29-2016, 04:46 PM
300deluxeL79's Avatar
300deluxeL79 300deluxeL79 is offline
have the same compressor, i've used heater hose on the flat end to keep it from slipping
Old 05-29-2016, 05:27 PM
Good idea, that would work nicely as well.
Ryan
Old 05-30-2016, 12:25 AM
Drivers side coil spring installed &quot;I can't believe it's not butter&quot;
Smooth!!!!!
Ryan
PS: Now started to put the stabilizer end links on just because they were handy, but hard to get the thread started, put them together and tightened them up a bit out of the car to get them squeezed a bit.
