Old 05-19-2016, 10:03 PM
Ryan1969Chevelle's Avatar
Yup, pick up at MCACN, and I have the Evaporust ready to go:-)
Bob dislikes these:-)
Ryan
Old 05-19-2016, 11:07 PM
I am learning quickly about O-Type anti-spin rears:-)
Chatted with Greg Rollin at Supercars Unlimited, and Brian Trick Olds rear expert, and I now have the confidence to set up my "Posi" and get it hung on my chassis. Also Tweed V. And Dave H are helping me on FB (It takes a community)
Thanks to all 4 guys!!!
Now I want to build a 4.66 for PSMCDR but need to focus!!!
I like these rear ends as the axles
Ryan
Old 05-20-2016, 02:08 AM
Ended up adding 0.012" to each side of the posi to bring it back within specs:-)
She should grab and go now:-)
Ryan
Old 05-20-2016, 11:41 AM
A couple more little items like putting the axles back in, red Loctite here and there, adding gear oil and posi additive, gasket and cover, and I hope to install this weekend.
I can't find my NOS posi tag.......... yet.........
Ryan
Old 05-22-2016, 10:03 PM
Home run today!!
Wrapped up the rear end rebuild.
Red locktite for the pinion nut and cross shaft bolt, sealant on the pinion yoke splines, and white lithium grease on the seal surfaces. Then Lucas gear oil and GM posi additive:-) I even restored the original cover bolts. Done!!
My neighbor, Jamie and I installed the differential in the frame, that felt good!! I put the springs and insulators in. Next step is to paint the shocks and install. (I am using generic shocks as the repop spirals are so expensive and these are an easy upgrade in future if the need arises) I also may get drag shocks for PSMCDR)
Old 05-22-2016, 10:09 PM
More pictures:-)
i even restored to cover bolts, they have nice markings:-)
Ryan
Old 05-22-2016, 10:10 PM
Dan specifically asked for an action shot of Dr Olds making his brew:-)
Ryan
Old 05-23-2016, 01:48 AM
WRONG, JUST WRONG [img]<<GRAEMLIN_URL>>/rolleyes.gif[/img] [img]<<GRAEMLIN_URL>>/no.gif[/img] [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
Good one [img]<<GRAEMLIN_URL>>/burnout.gif[/img]
Old 05-23-2016, 01:49 AM
There is a Check-Mark above your head [img]<<GRAEMLIN_URL>>/dunno.gif[/img]
Old 05-23-2016, 02:18 AM
matt5708 matt5708 is offline
Just wanted to say that this is one of the more interesting threads and a cool story about a great car. I have been following from the beginning, and I admire what you are doing.
Keep up the great work, and I appreciate you sharing your story.
Matt
