Go Back   The Supercar Registry > Sponsors > Boulder Motorcar
Old 02-04-2025, 02:08 PM
napa68's Avatar
napa68 napa68 is offline
Default 1966 Corvette L72 Light Refresh
After I posted in the "birthday" thread, there seemed to be some interest in my latest acquisition. This 66 coupe is features all born with drivetrain, trim tag, VIN tag, and most all original secondary dated components. The only exception I have found yet is the water pump (which I have sourced a properly dated unit). The NCRS Shippers Report indicates the car was officially produced Jan 10th 1966 being delivered to Marsh Hallman Chevrolet in Albany, NY. The car was later sold on May 19th 1966. Documented by it's original Protect-O-Plate and dealer invoice. The car is optioned with.
-L72 427-425hp
-M21 4 speed
-G81 3.70 positraction diff
-K66 Transistorized ignition
-N14 Side mounted exhaust
-P92 White stripe 7.75-15 tires
-U69 AM/FM radio
-A01 Tinted glass
The combination of a real L72 car, Nassau Blue with blue / white interior, and a factory side pipe car is just too irresistible to not keep around for a while (or longer). It's an original paint car, with a really nice original interior. Good docs, great colors (IMO). I bought this car from a friend, so I did not travel to inspect the car nor have anyone look at it (mistake)
Sometimes these cars play well, and other times not so much. This one fought me right off the trailer. When the car arrived, it was about 10F degrees. The battery was not up to the task first of all. Then after rolling the car out of the trailer, I was able to get the car started with a jumper pack. That led to a carb that was hemorrhaging fuel. I'm thinking to myself this ain't starting out too well. With the addition of a fresh battery (old one was 5 years old) and a carb rebuild, I got the car fired up and proceeded to tune on it a bit. Actually runs pretty good (especially when one considers this still has the original plug wires on it yet). I'm thinking to myself maybe the worst is over? I did discover though there were some more items that were inop than what was presented to me when I bought the car. Most notably the fuel gauge, temp gauge, back up lights, and wiper motor (but wait.....there is more).
I knew the clock and radio did not work going into this. Soooooo, I popped the clock to send that out, and then diagnose the radio situation. I was pleasantly surprised to find the speaker was the culprit. Ironically, I had just gotten a couple mid year speakers rebuilt by Jackson Speaker Service and they were on the shelf. Radio now sounds great and works like a charm.
On to the rest of the issues.........
On my initial examination, I also discovered the speedometer was disconnected at the trans. I do know for certain the car had accumulated about 100 miles since 2022 (last time the car was advertised). It's a safe assumption there is an issue of sort, so I pulled the tach and speedo to send that out to my speedo guy in Milwaukee. I have had people ask me where I am sending this type of work to, so here is the link to his shop. He (Roger) is very knowledgeable and turns the work around quickly.
http://www.speedometersolutions.com/
I then proceed to diagnose the rest of the inoperative items.
1. Fuel gauge
2. Temp gauge
3. Back up lights
4. Wiper motor
The first 3 items have a common source for power. After testing for continuity in all of the respective circuits, I find a pretty good voltage drop in the main dash harness. I peeled that apart to find at least 1 issue. Furthermore, there was another issue I discovered to boot in the main harness. So, I've got a new main harness on order. I'll also add this car must of had an electrical issue previously, as the engine harness had been replaced.
The car is showing 65k miles on it. I see freeze plugs with imprints on them, along with Fel Pro head gaskets. We now know it has some type of rebuild on the engine (which is fine IMO). I am always a bit concerned with an original engine due to the nylon timing gear. I scoped the bores to have a look. I appears as though the engine retains it's original domed pistons? I did not see any sort of imprints on the tops of the pistons, and also saw hone marks (along with a few scuffs). It would be great if this had the original size bore and proper compression. They always seem to run a bit better when they have some squeeze. The plugs looked decent given the lack of activity the car has had in recent years. The valve lash was really close when I checked it all. But, while I'm here, I ran all of the valves.
Today, I'll bench test the wiper inop wiper motor and see what needs to be done there. If I can get it going, I'll put new rubber components in the washer pump and clean everything up the best I can. One of the headlight motors is really lethargic (another item my "friend" neglected to tell me). So I'll get both of those out, clean the armatures in both, clean out the old grease in the transmission side of the motors, lube everything up and see where that takes me.
The Following 22 Users Say Thank You to napa68 For This Useful Post:
03fridge (02-05-2025), 1967 4K (02-04-2025), 60sStuff (02-05-2025), 67since67 (02-04-2025), big gear head (02-04-2025), Carleen (02-12-2025), carnut4life (02-04-2025), cheveslakr (02-04-2025), Chuck_Burg (02-04-2025), dykstra (02-04-2025), juliosz (02-05-2025), L78_Nova (02-06-2025), L_e_e (02-04-2025), Nasblu (03-13-2025), olredalert (02-04-2025), PeteLeathersac (02-04-2025), RCH (02-02-2026), RPOLS3 (02-04-2025), Steve Shauger (02-04-2025), Tenney (02-05-2025), YenkoYS-199Stinger (02-05-2025), Z282NV (02-05-2025)
Attachments - The Supercar Registry IMG_20250508_134838.jpg IMG_20250508_134830.jpg IMG_20250508_134821.jpg IMG_20250310_123911314_HDR.jpg
Old 02-04-2025, 03:07 PM
RPOLS3's Avatar
RPOLS3 RPOLS3 is offline
Love following along on these threads - this car checks all the right boxes too.......
Jake Dykstra
Dykstra Motorsports
The Following User Says Thank You to RPOLS3 For This Useful Post:
napa68 (02-04-2025)
Old 02-04-2025, 05:15 PM
67since67's Avatar
Yet ANOTHER reason for a visit to the Boulder Beer Bar!!
You are having too much fun Tim!
The Following 4 Users Say Thank You to 67since67 For This Useful Post:
dykstra (02-04-2025), napa68 (02-04-2025), olredalert (02-04-2025), RPOLS3 (02-05-2025)
Old 02-04-2025, 10:05 PM
dykstra's Avatar
dykstra dykstra is online now
What a great car! Love this!!
Dave Dykstra
NCRS#66003
Dykstra Motorsports
The Following 2 Users Say Thank You to dykstra For This Useful Post:
napa68 (02-04-2025), RPOLS3 (02-05-2025)
Old 02-05-2025, 02:11 AM
Steve Shauger's Avatar
Administrator
Tim you are amazing and when this has had your touch it will be perfect! Look forward to this "Light Refresh" progress.
www.vintagecertification.com
The Following 2 Users Say Thank You to Steve Shauger For This Useful Post:
napa68 (02-05-2025), olredalert (02-05-2025)
Old 02-05-2025, 12:33 PM
napa68's Avatar
I got into the wiper motor yesterday, and that endeavor was a bust. I'll need some professional help there. FWIW, that has been suggested to me more than a few times prior
Here is what I did rebuilding one of the headlight motors. More often than not, the grease in them gets so gummed up, electrically they are fine. Just a good cleaning and reassembly is all that is needed. I keep the gears in stock, as sometimes they have a section that gets worn and can bind up a little bit.
Some time in the ultrasonic cleaner with Purple Power (I left the field housing alone to preserve the ink stamp). Here is the old gear (left) compared to the new gear
Perfect date for a January 66 car
And reassemble with white lithium grease
As mentioned before, the car is a New York car. What history I can put together this far, the car was in NY until 1995. The car had received a Bloomington Survivor Award in 1993 on all parts of the car with the exception of the chassis. Certainly, that program has become much more stringent since then. Regardless, I busted out the Go-Jo to start soaking, degreasing and cleaning the chassis.
A few before pics. The chassis is VERY solid, just not a California car.
And the first soak......
The Following 13 Users Say Thank You to napa68 For This Useful Post:
03fridge (02-05-2025), 60sStuff (02-06-2025), 67since67 (02-05-2025), big gear head (02-05-2025), Chuck_Burg (02-05-2025), dykstra (02-05-2025), juliosz (02-05-2025), L78_Nova (02-06-2025), Roger M (02-05-2025), RPOLS3 (02-05-2025), Tenney (02-05-2025), YenkoYS-199Stinger (02-05-2025), Z282NV (02-05-2025)
Old 02-05-2025, 02:09 PM
TimG TimG is online now
The car is looking good, Tim. I want to see chassis pictures as you progress. If there is a '66 worthy of this type of mechanical rebuild, this is the car.
The Following User Says Thank You to TimG For This Useful Post:
napa68 (02-05-2025)
Old 02-05-2025, 06:55 PM
60sStuff's Avatar
60sStuff 60sStuff is offline
Tim,
Your endless energy spent on refining top of the line Corvettes that you seek out and bring to BMC is exciting to watch.
And yet “another” gauge cluster, soon with eyes closed.
Thanks for sharing the preservation of such awesome cars!
Chris.
The Following 2 Users Say Thank You to 60sStuff For This Useful Post:
napa68 (02-05-2025), Steve Shauger (02-05-2025)
Old 02-06-2025, 02:14 AM
napa68's Avatar
Originally Posted by 60sStuff View Post
Tim,
Chris.
Thanks Chris. One item I have learned from pulling all of these clusters, the speedo heads and tach units need love. In this case, both units had bushings that were out of them, as well as the magnets. I was told by Roger today, the odometer while it worked, would have taken out the speedo cable sooner than later. The tach was wandering ALL over above 2500 rpm. It would have not been long before that shit the bed.
With shipping both ways, I'll have about 750 invested in that alone. It's not cheap nor easy to do these things correctly. It's the right thing to do. I'll have an update tomorrow on the chassis. So far, I'm happy with the results.
The Following 9 Users Say Thank You to napa68 For This Useful Post:
1967 4K (02-06-2025), 60sStuff (02-06-2025), 67since67 (02-06-2025), 69M22Z (02-06-2025), cheveslakr (02-06-2025), dykstra (02-06-2025), olredalert (02-06-2025), PeteLeathersac (02-06-2025), YenkoYS-199Stinger (02-11-2025)
Old 02-06-2025, 01:28 PM
napa68's Avatar
Yesterday was a long and dirty day of cleaning / preserving the chassis on the car. Considering the history of the car and where it spent a good amount of it's life, I'm happy with the results. You'll see the non OEM shocks in the pics.....those are old school Koni's As I have mentioned before, I have more history to seek, prior to 1995.
There is some evidence the car was used for it's intended purpose. The car is not documented to be an F41 suspension in the car, yet there is an F41 front sway bar, F41 rear spring (aftermarket bolts securing it to the trailering arms) and the aforementioned Koni's. The lips on the rear wheel wells were shaved assumingly for larger rear tires.
I had ordered up a set of tires for the car right after it landed. When purchasing the car, I was told the tires were new back in 2022. He wasn't lying, they were new TO THIS car. They were reproductions from (what I figure) back in the 90's. Made in Argentina. They were just about as hard as some of the original non DOT's I've mounted and dismounted. The spare is the original Firestone Deluxe Champion, so I followed suit with the new skins. Another little surprise, was none of the wheels were original to the car. They were all 15x6 (should be 15x5.5). One of them was not even a GM wheel. Luckily, I had a nice survivor set of 65-66 wheels at the shop.
Today's task, get this installed.......
1967 4K (02-06-2025), 60sStuff (02-06-2025), big gear head (02-06-2025), Chuck_Burg (02-06-2025), Dave Rifkin (02-23-2025), dykstra (02-06-2025), L78_Nova (02-06-2025), Nasblu (03-13-2025), olredalert (02-06-2025), RPOLS3 (02-12-2025), Tenney (02-07-2025), YenkoYS-199Stinger (02-11-2025), Z282NV (02-06-2025)
