Old 04-13-2010, 02:33 PM
kwhizz kwhizz is offline
Default Re: 37 Ford LS2 Continuation thread
The air intake looks great...
I remember all of the looking at SEMA for just the right part...
Yep!!......................That one part makes everything fit
Ken
Old 04-14-2010, 03:02 PM
Got the new thermostat housing in, it will make getting a lower radiator hose to fit a lot easier and will look neater......Before and after
Also neatened up the towers for the windshield wipers, there used to be a nut holding the unit together and a threaded stud that a big nut went on that held the wiper arm on...........cut off the stud and tapped the shaft and threaded the inside of the tower guide to eliminate the nut.....cleaned it all.....I'll make a decorative cap that will probably be installed and just install the wipers if needed..........
also got the heater hoses installed and heres a shot of the Volkswagen Beetle wiper assembly modified and installed, also the defrosters are hooked up.....
Waited all day yesterday for the Fedex truck to show up with the parts I need, he ended up showing up after everyone went home according to the tracking info.....hopefully that won't happen today.....Wheels and Tires are promised for Friday....going to the upholstry shop in a week and a half
Ken
Old 04-14-2010, 04:56 PM
Will this rod pass the state inspection or do they give you an exemption for being 63..
Old 04-14-2010, 05:38 PM
Looking great Ken!
Did I miss it or...what happened with the windshield...what did you end up doing?
Old 04-14-2010, 05:41 PM
ORIGLS6 ORIGLS6 is offline
Not sure about Wisconsin but you can get anything passed in Illinois (Chicago), .................... with a big enough check!
Ken,
Is that Thermostat housing a Qualitek product?
Old 04-15-2010, 04:05 AM
Looking great Ken!
Looks like I'm stuck with the windshield, I think I can fix the rubber seal to make it look a lot better, If I can make it acceptable I'll leave it in.....If not....Out it comes and I'm back to flat 2 pc glass with a seam.........which is what I should have done in the first place......
Ken
Old 04-15-2010, 04:06 AM
Ken,
Street and Performance product.......
Old 04-15-2010, 04:17 AM
I picked up the driveshaft and got it installed today, filled the trans with fluid.......started the car with the rear wheels off the ground and ran it thru the gears .....also got the radiator hoses installed.....No leaks anywhere.....so far so good!!.........Then the Fedex truck shows up with the GTO Body Control Module and the Powertrain Interface Module........Great...Now we can try and get the dash module functioning.....open the box....take ouit the modules...........Damm!!...........No Plugs.......I reminded them a couple of times that the modules are useless without the plugs......Darn!!......Now we do the waiting thing again......
Ken
Old 04-15-2010, 05:47 AM
L-79 Nova L-79 Nova is offline
Excellent work Ken,can't wait to see it with skins on it. Ron.....
Old 04-15-2010, 08:02 AM
I wonder if suppliers even listen anymore...and sometimes I wonder how they stay in business
