Old 06-16-2020, 01:23 PM
Lee Stewart's Avatar
Atlantic goliath grouper
earntaz (06-16-2020)
  #14962
Old 06-16-2020, 01:35 PM
P-40 Warhawk’s
downunder1 (06-18-2020), dykstra (06-17-2020), earntaz (06-16-2020), olredalert (06-16-2020), PeteLeathersac (06-16-2020)
  #14963
Old 06-16-2020, 06:30 PM
Lee Stewart (06-16-2020)
  #14964
Old 06-16-2020, 08:46 PM
What maketh a Mach 1 in the 21st century? Let’s start with what’s under the hood. All Mach 1 Mustangs will come with a 5.0-liter Coyote V-8 good for 480 hp at 7000 rpm and 420 lb-ft of torque at 4600 rpm. According to Ford, it’s essentially the same revised Mustang GT motor as in the outgoing Bullitt, albeit with a slightly different ECU tune. GT350 bits include the intake manifold, oil filter adapter, and engine oil cooler, which all together improve engine oil cooling by 50 percent compared to the standard GT. The Mach 1 will also get two side heat exchangers, one for engine oil and the other for transmission oil, in addition to a rear axle cooling system. The Mach 1 also adds a lower diffuser and rear tire spats sourced from the GT500.
A six-speed Tremec 3160 manual transmission from the GT350 is standard, offered for the first time with rev matching, but you’ll have the option of a 10-speed automatic. The automatic, which is also used in the Mustang GT and F-150, receives an upgraded torque converter and unique tuning for the Mach 1, along with a secondary air-to-oil cooler to enhance cooling capacity by 75 percent.
https://www.hagerty.com/media/news/r...ustang-mach-1/
Old 06-16-2020, 10:31 PM
The Goliath birdeater spider is a stealth hunter in South American forests. The Goliath birdeater is the king of spiders. Weighing up to six ounces and with a leg span of nearly a foot, this tarantula is the largest arachnid on the planet.
Old 06-16-2020, 10:34 PM
The goliath frog otherwise known as goliath bullfrog or giant slippery frog (Conraua goliath) is the largest living frog on Earth. Specimens can grow up to 32 centimetres (13 in) in length from snout to vent, and weigh up to 3.25 kilograms (7.2 lb). This species has a relatively small habitat range in Cameroon and Equatorial Guinea. Its numbers are dwindling due to habitat destruction and its collection for food and the pet trade.
Old 06-16-2020, 10:36 PM
GOLIATH TIGERFISH
Old 06-16-2020, 10:45 PM
Old 06-16-2020, 10:52 PM
Old 06-16-2020, 11:00 PM
