Old 03-19-2026, 10:19 PM
Too Many Projects's Avatar
Since you are planning to remove the trans, just pull the engine and do it right. You may get that leak to slow down some, but never completely stop with a bandaid. If it is a 1 piece pan gasket, there is WAY too much sealer on it and that will push the gasket out like that.
Mitch
1970 Chevelle SS
1966 Chevelle SS
1967 Camaro ss/rs
The Following 3 Users Say Thank You to Too Many Projects For This Useful Post:
Arrowsmith (03-20-2026), big gear head (03-20-2026), olredalert (03-20-2026)
  #132
Old 03-19-2026, 10:42 PM
'69Novajoe's Avatar
'69Novajoe '69Novajoe is offline
Originally Posted by RPOLS3 View Post
Can you loosen the pan bolts enough to gently shove the gasket back in position with a prybar or screwdriver?
I think what you're looking at is actually the RTV that might have been "pushed" out due to crankcase pressure?? That was the reason I wanted to try that adjustable PCV, to see if it might lessen it?? I'll know more when I get back under there to try and move it around or just cut it off?!
I ain't as good as I once was, but I'm as good once as I ever was.
Old 03-19-2026, 10:50 PM
'69Novajoe's Avatar
It sounds so easy when you say it like that!!! And, I know, what you're saying about doing it "right", but I'm already having flashbacks about how long it's taken to get it to this point. I'm not sure I have it in me to go through all of that again!! I've pretty much agreed (with myself!!) to live with an oil leak at this point.
