Old 12-09-2019, 12:25 PM
ALLZS ALLZS is offline
What style & color are the fuel line clips on the rear frame rail
Old 12-09-2019, 12:37 PM
napa68's Avatar
napa68 napa68 is offline
I'd pull it GW. I think you'll be so much happier with the results later on. Even though you are not restoring, the cleaning and detail process will be so much easier and effective.
Besides.................I want this thread to keep going
Nice work so far!
TopRat (12-10-2019)
Old 12-09-2019, 05:47 PM
m22mike's Avatar
m22mike m22mike is offline
x2 on removing the engine, to much aggravation trying to work around it, you will be glad you did. And with that said you could paint the inner fenders at that point.
Now git er done Graeme
Mike
Old 12-09-2019, 07:33 PM
NorCam's Avatar
NorCam NorCam is offline
Ahhh I knew you guys were both gonna say that.
The engine tilter was actually placed on the intake yesterday and I was leaning on doing that. Also thinking of a cam swap and some other maintenance. I'll pull the motor later in the week.
napa68 (12-11-2019)
Old 12-09-2019, 03:23 PM
NorCam's Avatar
Can't tell you what color they are because the PO fluffed the underside and painted it black when he put it back on the road prior to selling it. I'm about to pull the lines down and try and wash them up. The clips and fasteners will all be soaked in evapo rust to clean them up before going back on. With any luck the clips will show some more originality once cleaned up. The head markings on the bolts used on the rear frame rails are ER while the front sub frame has a couple mixed markings including an anchor style. Pics are from back of car to front.
Back upper frame above axle
Back vertical rail above front of axle
Crossover clamp ahead of spring perches
Outer rocker mount mid chassis location
Front outer sub frame
front outer sub frame closest to RF wheel
Old 12-09-2019, 03:50 PM
great let me know what you find thanks
Old 12-09-2019, 07:49 PM
RPOLS3's Avatar
RPOLS3 RPOLS3 is offline
Scope creep already...……...
Jake Dykstra
Dykstra Motorsports
Old 12-10-2019, 12:44 AM
NorCam's Avatar
I know right. I've been trying to tell myself to stay grounded and not go too far with this thing. I'll have another good look at it tomorrow and see how just how much detailing I want to do around the engine to make a final decision on that front.
Old 12-10-2019, 01:06 AM
Ryan1969Chevelle's Avatar
Pull it!!!!
That way you can access the body mount bolts easily.
Ryan W31
Old 12-10-2019, 02:46 AM
NorCam's Avatar
Originally Posted by Ryan1969Chevelle View Post
Pull it!!!!
Ryan W31
I'm not pulling the sub frame...and I'm not restoring this car.
