Old 12-01-2008, 03:00 AM
Default Re: really cool 70 Z28..simply the best.
radiator tag
Old 12-01-2008, 03:04 AM
ORIGLS6 ORIGLS6 is offline
Great pix. Thank You Sir!
Old 12-01-2008, 03:18 AM
oil filter with undercoat
Old 12-01-2008, 03:20 AM
Old 12-01-2008, 03:21 AM
Stefano Stefano is offline
That would be the original oil filter.
drain plug
Old 12-01-2008, 03:24 AM
firstgenaddict's Avatar
Hey that is the 2nd or third survivor rad tag I have seen that has had white paint on the letter code... I see that they must have used a pad stamp as you can see where the corner of the stamp hit on the left top. Had to have been to highlight the code for easier ID on the line.
~JAG~
NCRS#65120
NUMEROUS Lemans blue Camaros,
& a Chevelle or two...
Old 12-01-2008, 03:25 AM
I see the same highlighting of white paint on my PA radiator tag. Like mine, looks like they highlighted these tags with a roller of some sort. Really cool car Charley.
Chris
Old 12-01-2008, 03:27 AM
How are you ever going to drain that original virgin oil and change the oil filter?
Dan.
Old 12-01-2008, 03:36 AM
You may be able to get most of it out through the dipstick hole using a section of copper tubing which will fit through the dip stick hole... I would use the dipstick hole trick first then refill with oil, circulate fresh oil by pulling dist and priming (which will put it through the filter) then pull it out through the dip stick again... that should pretty well flush it.
~JAG~
NCRS#65120
