Old 04-20-2020, 02:48 AM
Lee Stewart's Avatar
454_Malibu (04-20-2020)
  #13792
  #13793
Old 04-20-2020, 02:51 AM
  #13794
Old 04-20-2020, 02:52 AM
Old 04-20-2020, 05:26 AM
No scrub pad? Use aluminum foil as a temporary replacement. Crumple a handful and scour to polish stainless steel pots (foil may damage nonstick pots).
Old 04-20-2020, 05:28 AM
Soap scum can block pipes in dishwashers, causing the machines to not drain properly or even break down. Before you pay a plumber, pour Kool-Aid mix into the detergent dish and run a regular cycle with the machine empty. (Any color is generally fine, but if the thought of adding red powder to a white machine makes you shudder, stick to lighter shades.) The Kool-Aid’s citric acid removes soap scum.
Old 04-20-2020, 05:31 AM
To loosen stubborn glue dried on scissors or a counter, cover it with WD-40. It can dissolve the adhesive components of even strong glue to make it easier to remove.
See! Instead of Rock, Paper, Scissors . . . it's Zip Ties, Duct Tape, WD40!
Old 04-20-2020, 05:33 AM
Fill the chamber of a drip coffeemaker with water. Drop in four Alka-Seltzer tablets. Once they dissolve, run a brew cycle to wash the machine’s tubes. Rinse the chamber two to three times, then run another brew cycle with plain water. The sodium bicarbonate (baking soda) and citric acid in the effervescent heartburn aid make it a powerhouse cleaner.
Conventional cleaners don’t dissolve stubborn soap buildup on shower doors. Spray the glass with cooking spray and leave for 30 minutes. The oil slides between the glass and the soap scum, making it easy to wash. Wipe off with soapy water (use a wet sponge with a drop of dishwashing liquid).
Old 04-20-2020, 05:35 AM
Just cooked fish? Painted a room? Pour vinegar into a glass or bowl, and set it in the affected room for 30 minutes. Vinegar neutralizes odors
