Old 03-22-2016, 02:09 AM
Ryan1969Chevelle's Avatar
Terry and I went to Waterloo to pick up the primered rims, and the frame.
Dropped off the rear lower control arm after a little metal work.
I found the VIN on the frame:-) A little tough to see but i got a few good pictures:-)
Had a great engine building conversation on the way back, Ramblers and Oldsmobiles are similar in a few ways..... 6 inch rods and hard to find parts.
Thanks Terry!!!!! "It takes a village"
Ryan
Old 03-22-2016, 02:22 AM
Double W-31 Delight today!!!! Mail Man showed up with another load of Inline Tube parts:-)
Lots of little items:-)
Engine and trans mounts, hoses, u-joints, stickers, emblems, core supports, rad saddle mounts and shims, gas tank straps, exhast manifold gaskets, thermosat, and gasket, rear axle to backing plate gaskets, wheel well moulding screws, rear sway bar shims, bolts, nuts, washers, gas tank vent, clutch boot, etc, etc!!
The stickers are a little premature but while I was having items shipped (might as well)
Ryan
Old 03-22-2016, 02:25 AM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Alss</div><div class="ubbcode-body">looks like your axle vent got tore up [img]<<GRAEMLIN_URL>>/frown.gif[/img]..if ya need one.......... </div></div>
Yup I need one, can you add one to my parts pile at Gladi's? Pick Up at NOCC?
Ryan
Old 03-22-2016, 06:45 PM
JpMotorsports JpMotorsports is offline
Send a message via Yahoo to JpMotorsports
Very cool. You must had one he part order form from Inline tube! Cant wait to see this thing go back together
1982 Pontiac Grand Prix- Dove Gray (Turbo LS swap in the works!)
1967 Chevelle SS396- Tuxedo Black- SOLD
1972 Oldsmobile 442 W29 Convertible- Sunfire Yellow- SOLD
1969 Chevrolet Chevelle/Malibu- Dover White- SOLD
1986 Oldsmobile Cutlass Supreme- Silver- SOLD
1987 Chevrolet Monte Carlo SS- Maroon- STOLEN
Old 03-22-2016, 07:31 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: JpMotorsports</div><div class="ubbcode-body">Very cool. You must had one he part order form from Inline tube! Cant wait to see this thing go back together </div></div>
I am a little bit addicted to Inline Tube:-)
&quot;Cant wait to see this thing go back together&quot; Me too!!!!
Ryan
Old 03-23-2016, 03:24 AM
I got the small repair rings laid out on the bare frame:-)
Measured a few hundred times, used an original frame dimensioned drawing.
All the diagonal measurements look good plus or minus an eighth of an inch.
Plan to try to get these welded Thursday after work........ so I can get the frame back to the media blaster.
I should have shiny parts next week, on my revised schedule I need to be done the frame this month:-)
Making some engine plans, in a couple weeks I will visit FJ Smith in Cayuga, we seemed to be on the same page with my goals and budget and they dyno tune everything (which is one of my main sticking points)
Also inventoried all my new parts:-) one little issue but Inline will fix it up no problem:-) Last time I thought I was missing the tiny U shaped brake lines from the flex line to the wheel cylinders up front and had to force him to hold off till I could check and double check.
Also somehow I bought a tire pressure sticker for a Hurst Olds with 15 inch tires, I can give it away at PSMCDR to the Polyglass Pimp:-)
Ryan
Old 03-23-2016, 03:35 AM
U-shaped brake lines [img]<<GRAEMLIN_URL>>/no.gif[/img] [img]<<GRAEMLIN_URL>>/haha.gif[/img]
Remind me to let you in on a little secret about these [img]<<GRAEMLIN_URL>>/wink.gif[/img]
Are your original gas tank straps missing? What is wrong with them?
Old 03-23-2016, 05:37 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Postsedan</div><div class="ubbcode-body">U-shaped brake lines [img]<<GRAEMLIN_URL>>/no.gif[/img] [img]<<GRAEMLIN_URL>>/haha.gif[/img]
Dan </div></div>
Brake line class at NOCC, Deal
The original gas tank straps looked pretty rough, I haven't tried to restore them, and this could be an item that I &quot;over bought&quot; When things start going back together I am trying to be as prepared as possible. Tiny things can hold me up especially being in Canada (Those parts took weeks to arrive) The originals and the new are galvanized so if my originals will shine up perfectly I will use them and sell the new parts.
Ryan
Old 03-23-2016, 05:45 PM
A few pictures from preparing last night to repair the two body mount holes second from the back of the frame on both sides.
Old 03-23-2016, 09:10 PM
Woj's Avatar
Woj Woj is offline
Looking good Ryan. That frame cleaned up pretty well.
Keep up the good work.
Phil Woj.
