Old 11-25-2003, 08:08 PM
Steve_Hoog's Avatar
Steve_Hoog Steve_Hoog is offline
Default Re: 70 Judge RAIV and V continuation
Don
Gary; the owner of the Silver Judge, would like to know if you know him personally?
Old 11-26-2003, 12:46 AM
tjs44 tjs44 is offline
I REALLY hate to throw something else on the dead horse,BUT,after looking at my block numbers on my RA V block,I think that any test engne sent out by the factory would be a developmental engine.They all would have been DS part numbers.My block has DS-1001,under that EO-3777 and under that*5.to the right and between those lines is 98V-400RV-05.I have never seen or had a set of 400 heads that were taped for smog.I have seen and have owned 303 heads that were tapped for smog.AND as far as I know there has only been one set of GTO exhaust found for the GTO body.This further makes me think there were NO factory installed V motors to go to the public in anyway in a GTO.If any V motor was factory installed I think it would have been a 303 WITH a smog pump and castiron exhaust.IMHO,Tom
Old 11-26-2003, 12:53 AM
DaJudge DaJudge is offline
You have posted some great info regarding the RA V. What cars are your RA V's in ? In 1971 David Pearson ran a GTO in NASCAR , it is in fact the only GTO to have ever run in NASCAR. The piece I read stated that the cars ran well but the motors would not last. Does anyone know if that may have been a RAM AIR V? ( I will try to find the piece and post it) [img]/ubbthreads/images/graemlins/beers.gif[/img]
<span style="color: blue">1970 GTO Judge Ram Air IV, 4 speed</span>
Old 11-26-2003, 01:10 AM
two more [img]/ubbthreads/images/graemlins/[/img]
Old 11-26-2003, 01:14 AM
My RA V motor is a developmental ALU block with all RA V stuff EXCEPT exhaust.I own the exhaust but am running Nunzi headers.It is in a real 69 T/A.I am building a COMPLETE 303 short deck 2-4 Xram SCCA engine.It will be stroker motor,390CI.It will have the correct dist,balancer,X ram 2-4 intake and exhaust.
The Nascar engine was a 366CI engine,it used a std. deck block as far as I remember.
Last one checkout the CID callouts on the hood 366 CID. A ram air V under the hood? It would be interesting to know, it would explain where some of the engines wound up . These shots were taken at the 71 Southern 500. [img]/ubbthreads/images/graemlins/beers.gif[/img]
Old 11-26-2003, 01:17 AM
Great car to put it in right where it belongs. The callouts on the hood of Pearson's GTO is 366 CID . Pretty interesting. [img]/ubbthreads/images/graemlins/[/img]
Old 11-26-2003, 01:36 AM
by the way,my iron 400 AND my alu 400 V blocks BOTH have the DS1001 numbers?
Old 11-26-2003, 01:49 AM
GTO_DON GTO_DON is offline
Default Re: 70 Judge RAIV and V continuation *DELETED*
Post deleted by Charley Lillard
1969 GTO convert RAM AIR 4spd
1964 GTO convert survivor
Old 11-26-2003, 02:02 AM
Just when the last embers were dying down....
-S
