Old 04-11-2022, 04:56 PM
RPOLS3's Avatar
RPOLS3 RPOLS3 is offline
Two steps forward and one step back .............I decided to move the cars around yesterday and work on getting the garage set up for warmer weather. Roads are also now clean enough to allow for some behind the wheel time. Chevelle brakes work great but found another "minor" issue. The trans will not shift out of first gear. I assume this was a vacuum issue even though everything was hooked up - or so I thought. I sent Eric a picture of vacuum hose routing on the new carb, which I thought was the same as my old speed shop Holley it replaced - but it's not. I have the vacuum modulator and vacuum advance hooked up to the TCS port (this is a 70 specific carb) and there is not sufficient vacuum on the TCS port. Eric was kind enough to call me and walk me through how to get things re-routed. I need to search through my parts to see if I have the proper intake manifold fitting with another port to hood up the vacuum modulator line and then "T" into the choke line for the vacuum advance. To be clear this is not an issue on Eric's end - I had it plumbed incorrectly. I sent him the picture at 7:15 this morning and by 7:45 he had it diagnosed and solved. Onward!
Jake Dykstra
Dykstra Motorsports
The Following 5 Users Say Thank You to RPOLS3 For This Useful Post:
67since67 (04-11-2022), dykstra (04-11-2022), L_e_e (04-21-2022), napa68 (04-11-2022), Xplantdad (04-11-2022)
Old 04-11-2022, 08:52 PM
----Jake,,,,So many variations of that vacuum fitting. I have several different ones so if you can find a picture of the right one I may be able to give you one!.....Bill S
dykstra (04-12-2022)
Old 04-12-2022, 12:36 PM
RPOLS3's Avatar
Thanks for the offer Bill - I've got one coming.
Jake Dykstra
Dykstra Motorsports
Old 04-16-2022, 12:28 PM
RPOLS3's Avatar
My intake manifold fitting arrived yesterday and I installed it before I left to go do the tires on the 409. Took it for a quick test drive and the trans shifts as it should now. Also got a call from the electric motor guy and the defogger motor is ready to pick up - so I will get that on Monday. Finally coming together.
Jake Dykstra
Dykstra Motorsports
The Following 4 Users Say Thank You to RPOLS3 For This Useful Post:
1972convss454 (04-17-2022), dykstra (04-17-2022), napa68 (04-16-2022), olredalert (04-16-2022)
Old 04-20-2022, 12:41 AM
RPOLS3's Avatar
Finally back on the road - went over to the airport museum next door and snapped some pics with the evening sun.
Jake Dykstra
Dykstra Motorsports
The Following 11 Users Say Thank You to RPOLS3 For This Useful Post:
Chuck_Burg (04-20-2022), dykstra (04-20-2022), L_e_e (04-21-2022), mhurd (04-20-2022), napa68 (04-20-2022), olredalert (04-20-2022), ruralrte66 (04-20-2022), scuncio (04-20-2022), SS427 (11-30-2023), Stihl (03-12-2024), Too Many Projects (04-20-2022)
Old 04-20-2022, 01:18 AM
RPOLS3's Avatar
Some video if it running while I was taking the pictures.
https://youtu.be/10BCHxwihHo
Jake Dykstra
Dykstra Motorsports
dykstra (04-20-2022), olredalert (04-20-2022)
Old 04-20-2022, 01:26 AM
RPOLS3's Avatar
Proof that it runs well (way better actually) and the new Uniroyals produce much more smoke. If I only could figure out how to rotate the picture correctly.
Jake Dykstra
Dykstra Motorsports
The Following 3 Users Say Thank You to RPOLS3 For This Useful Post:
big gear head (04-20-2022), dykstra (04-20-2022), olredalert (04-20-2022)
Old 04-20-2022, 11:20 AM
dykstra's Avatar
dykstra dykstra is offline
Dave Dykstra
NCRS#66003
Dykstra Motorsports
The Following 4 Users Say Thank You to dykstra For This Useful Post:
67since67 (04-20-2022), CanCOPO (11-23-2022), napa68 (04-20-2022), RPOLS3 (04-20-2022)
Old 04-20-2022, 11:21 AM
dykstra's Avatar
Looks and sounds great Jake!! Now it runs as good as it looks!
Dave Dykstra
NCRS#66003
Dykstra Motorsports
RPOLS3 (04-20-2022)
Old 04-20-2022, 01:08 PM
Too Many Projects's Avatar
Wow !! The pics at the airport are way cool !! The car looks great...
Mitch
1970 Chevelle SS
1966 Chevelle SS
1967 Camaro ss/rs
RPOLS3 (04-20-2022)
