Old 12-05-2019, 12:46 PM
NorCam's Avatar
NorCam NorCam is offline
Originally Posted by 32KZ View Post
How about backspacing? 3.5"?
Part Number: 286-VN1055761
These have stock back spacing which is 3.75".
I buy them from Jegs or Summit when they have their big sales on and they are very affordable.
Old 12-05-2019, 04:34 PM
32KZ 32KZ is offline
Old 12-08-2019, 05:16 PM
NorCam's Avatar
The fun starts today Tim. Yesterday I started addressing some fastener changes on the engine and now it's time to pull the rad, remove the water pump and undress the bottom of the car beginning with the exhaust. Slow and steady cleaning of the significant areas will then begin prior to any new or restored parts going back on. Oh and thanks for the nice pair of NOS fender aprons I was able to pick up from a couple site members.
NOS aprons courtesy of Ken & Mark (one per side)
Found a nice screw to complete the coil bracket.
Swapped out the intake bolts to M head markings. I added hardened steel flat washers to protect from marring.
Also added correct original lift brackets which were missing.
napa68 (12-09-2019)
  #124
Old 12-08-2019, 07:00 PM
6667ss138 6667ss138 is offline
I know you are trying to put everything back correctly and detailing your engine compartment. I can't see it in your pictures. Do you have this bracket on your carb base to fuel line. Should be on later built cars, hard to find and expensive. Just curious. Beautiful car!!
http://www.camaros.org/forum/index.php?topic=12107.0
http://www.camaros.org/forum/index.php?topic=8747.0
The Following User Says Thank You to 6667ss138 For This Useful Post:
NorCam (12-08-2019)
  #125
Old 12-08-2019, 09:46 PM
NorCam's Avatar
I know the bracket you're talking about as I helped document one on a survivor LT-1 motor that an old friend had about 15 years ago, and no...that's missing from this car.
Old 12-08-2019, 10:16 PM
KLars1 KLars1 is offline
This thread ROCKS. What an awesome car, I look forward to the updates daily.
Help me find my Dad's cars!
Please visit: http://www.bydennislarsson.com/
The Following User Says Thank You to KLars1 For This Useful Post:
NorCam (12-09-2019)
  #127
Old 12-09-2019, 12:31 AM
Don't think I ever saw one of those fuel line brackets on a 1969 Z/28. Maybe very late cars?
The Following User Says Thank You to Salvatore For This Useful Post:
NorCam (12-09-2019)
  #128
Old 12-09-2019, 05:38 AM
NorCam's Avatar
Found another small 1970 related part on the car earlier today. While pulling back the coolant lines I noticed the thermostat housing is part #3972128 which was also used on 70 Z/28's and Vette's. Still had an original AC Delco thermostat in it and will now get cleaned up and reused. Seems that engine builder George Kulp liked his black gasket sealant. He rebuilt the motor and this stuff is everywhere. I'll be changing the fuel pump and the fuel line as it has been kinked in a couple spots and was routed outside of the water pump housing rather than underneath it.
Looks like the late 10E cars might also have gotten a 70 style thermostat housing with #3972128 rather than a 660 housing?
I'll soak this in carb cleaner for a couple of days and clean it up for reuse.
I'll also clean up this AC Delco 195 degree thermostat and test it before I reuse it.
Debating whether I'll pull the motor right out to get better access to cleaning up the inner fenders and the hard lines which were crudely painted.
I'll try washing the inner fenders down with enamel reducer to see if I can knock it back a bit and rid the drip lines they created when they painted them.
I'll also remove the battery tray and treat it to a bath in evapo rust to clean it up a bit. Overall the engine bay just needs a good clean up to unfluff it a bit.
TopRat (12-10-2019)
  #129
Old 12-09-2019, 12:25 PM
ALLZS ALLZS is offline
What style & color are the fuel line clips on the rear frame rail
Old 12-09-2019, 12:37 PM
napa68's Avatar
napa68 napa68 is offline
I'd pull it GW. I think you'll be so much happier with the results later on. Even though you are not restoring, the cleaning and detail process will be so much easier and effective.
Besides.................I want this thread to keep going
Nice work so far!
TopRat (12-10-2019)
