Old 08-19-2015, 07:55 PM
442w30 442w30 is offline
Default Re: 1969 Camaro Special Order Paint Process
If you picked a Mustang year, bodystyle, and color, I could tell you how many were built in similar odd combinations - they are out there.
Old 08-20-2015, 04:23 PM
JayR JayR is offline
This question has probably been answered many times previous, but was the process for ordering a special paint car? Was it done through the dealer? Did they go through the COPO system? Did all plants do special order paint cars?
Bob
The Canadian L79 Registry
Old 08-24-2015, 11:13 AM
Keith Seymore's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: JayR</div><div class="ubbcode-body">This question has probably been answered many times previous, but was the process for ordering a special paint car? Was it done through the dealer? Did they go through the COPO system? Did all plants do special order paint cars?
Bob </div></div>
I trust you read the first post in this thread...
[img]<<GRAEMLIN_URL>>/wink.gif[/img]
Additionally -
Special paint process, per author/historian Eric White (originally written for discussion on a Pontiac forum):
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: gtoric</div><div class="ubbcode-body">The procedure for getting a special-paint car ordered went like this:
• The customer (or dealership) determines what color is desired.
• An &quot;All Series Special Equipment&quot; order form is filled out.
The information required for a special-paint-request on this form is:
• Lower Color Paint No.
• Upper Color Paint No.
• Make of Car &amp; Year Paint Used.
I am guessing that obtaining the correct paint no. would be left up to the ordering salesman/dealership paint department.
In the '60s and early '70s, before colored plastic/fiberglass trim parts became common, any color paint could be ordered, as long as the dealer could supply the paint formula no. on the S.O. form. After the mid-'70s when the crash-bumper fillers became common place, special order colors were phased out except for large fleet orders.
Several codes were used on the Fisher Body trim tag to indicate a special-order paint. Codes varied between the years and between Fisher Body plants. Some of the codes used were:
1= Standard GM paint, not a Pontiac color
2= Special Pontiac color. Sometimes offered a half-year &quot;springtime&quot; color.
3= Cadillac FireFrost color. This paint was not normally allowed on a Pontiac build because of the special processes required to apply this type of paint.
4= Body in primer
SPEC or ** would indicate a paint color from a source outside GM (Ford, Chryco, AMC, John Deere, International Harvester, etc.) Colors could also be ordered to match school or business colors. As long as a formula no. could be identified by the dealership just about any color hue could be specified.
• The order was then routed through the Pontiac Zone office, which then routed it on to the Central Office.
• Central Office then entered a request to the paint supplier, usually PPG/Ditzler, for the appropriate paint.
• The paint supplier shipped a quantity of paint to the appropriate assembly plant.
• The special-order build was scheduled and coordinated between the Fisher plant and GMAD or Pontiac assembly.
• Build was delivered to dealership with a quart of touch up paint in trunk.</div></div>
I have also seen a double &quot;&amp;&quot; (double ampersand) to designate special paint, on a Pontiac plant cowl data tag.
Most assembly plants have/had a special paint system, separate from the main line, where smaller paint pots could be loaded with low production volume colors, which would minimize the amount of waste when flushing the system. Typically these were done for fleet and special equipment runs (Grand Trunk RR, RCMP, Bell Telephone, etc). We also have had some plants were the special colors were run through the paint repair line rather than the main assembly process.
K
'63 LeMans Convertible
'63 Grand Prix
Old 08-24-2015, 11:41 AM
Tracker1's Avatar
Tracker1 Tracker1 is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: 442w30</div><div class="ubbcode-body">If you picked a Mustang year, bodystyle, and color, I could tell you how many were built in similar odd combinations - they are out there. </div></div>
When you find a black Boss 302 Mustang, please let me know [img]<<GRAEMLIN_URL>>/smile.gif[/img]
I ain't nobody, dork.
Old 08-24-2015, 01:54 PM
69LM1's Avatar
69LM1 69LM1 is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Tracker1</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: 442w30</div><div class="ubbcode-body">If you picked a Mustang year, bodystyle, and color, I could tell you how many were built in similar odd combinations - they are out there. </div></div>
</div></div>
Here you go [img]<<GRAEMLIN_URL>>/smile.gif[/img]
J/K
Rich
Rich Pern
Old 08-25-2015, 06:07 AM
</div></div>
http://www.boss302.com/paint.htm
Old 09-18-2015, 12:56 AM
Tracker1's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: 442w30</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Tracker1</div><div class="ubbcode-body">
</div></div>
</div></div>
HaHa! Black Jade doesn't count! [img]<<GRAEMLIN_URL>>/beers.gif[/img]
