Old 07-21-2013, 11:29 PM
Default Re: Project: Hot rodding a 69 Nova
Took the day off to check out Super Chevy/Maple Grove.
This is some of this weeks progress
I blasted the steering wheel with glass beads, to scuff it enough for the paint to stick.
Painted wheel/came out great!
<a href="http://s533.photobucket.com/user/wrrose/media/100_3902_zpsa7b42827.jpg.html" rel="nofollow" target="_blank">
</a>
I decided to put the hood grills on the car, much like a 69 Copo Chevelle would have. Lots of careful measuring and remeasuring and more remeasuring, then I got the drill out and did it!!! Thats it for any exterior mods.
I stripped the bottom of the hood, then etch primed and top coated it with satin black.
Got the drive shaft stripped, painted. Then new u-joints and stripes, and installed in the car.
I also got the wheel wells blasted. After a bit of pitting repair from battery acid over the years, they will be primed and painted, hopefully this week.
69 El Camino
69 Nova
C7 Vette
Old 07-22-2013, 03:55 PM
68l30's Avatar
68l30 68l30 is offline
Looking great! Did you add the brackets at the rear of the hood to hold the inserts?
Looks like that wheel came out very nice!!
BIG
Old 07-22-2013, 09:02 PM
69VN's Avatar
69VN 69VN is offline
I'm jealous! Nice ride!!! [img]<<GRAEMLIN_URL>>/headbang.gif[/img]
Old 07-27-2013, 08:28 PM
The progress continues, although it took a detour this week. I wasn't planning on doing any body/paint work, but I had a little mishap, and dinged the hood. Not a problem really. I got some of the base coat with the car, and it's Sherwin Williams, the brand I always use. Dents fixed, and will be painted when I can get some booth time. The hood is scuffed. It just needs some color on a couple spots, then a couple coats of clear......Then sanding and buffing. So far it looks good.
I got the radiator support and inner fenders done. Had to do some pitting repair, but nothing too terrible.
I also got the whole smog system on the engine. All went well, except the the JUNK repro pump bracket. Luckily Albert's parts supply had a real one in stock.
I also got the driveshaft installed. That took about 5 mins.
Then I decided to blast the battery tray. Not sure what paint was on it, but the blast cabinet didn't even scratch it. So I broke out the paint remover. I think it was painted with the same paint they use on the bottom of the space shuttle.
I have some custom wire harnesses being made by American Autowire. They are great to work with, even if you're a pain in the a$$ like me, and want special wiring done. Donny is making me a harness that has all the plugs for the Shiftworks in dash tach.
Gonna take a break and head out to the Ohio Chevelle show. Lots to do when I get back.
69 El Camino
69 Nova
C7 Vette
Old 07-27-2013, 11:28 PM
L78racer L78racer is offline
maybe you know this but you are missing the u-bolt at the rear of the shifter bracket on the tail housing.
Old 07-28-2013, 12:04 AM
Bill,
Looking Fabulous, see you on Thursday....drive safe!
Old 07-28-2013, 12:56 AM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: L78racer</div><div class="ubbcode-body">maybe you know this but you are missing the u-bolt at the rear of the shifter bracket on the tail housing. </div></div>
It's not missing Paul, it was eliminated. The tail housing on the Autogear M22's is a larger diameter than a stock Muncie, so the u-bolt doesn't work/ too small. The mounting plate has been drilled for the Autogear trans. So it has regular 3/8&quot; bolts holding the mounting plate, much like a Chevelle set-up. The round part of the plate had to be re-ground to fit up against the larger diameter housing too........good eye though!! I got good advise from Ed Hartnett in Phily/the Muncie guru.
Yes Dan, we'll see you Thurs......looking forward to this one......big time!!
69 El Camino
69 Nova
C7 Vette
Old 07-28-2013, 12:13 PM
ok great. i built a hotrod from a 18k mile '68 granny nova years ago. LS6 w/077 heads, 4 spd. lotsa fun.
Old 07-28-2013, 12:37 PM
Nice! Was that color Island Teal or Grotto Blue?
Old 07-28-2013, 12:50 PM
the car was teal blue. blue custom interior.
