Go Back   The Supercar Registry > General Discussion > AMC
Old 03-20-2026, 09:48 PM
LetsFNgo's Avatar
LetsFNgo LetsFNgo is offline
Small update today:
The leaf springs showed up after their 120 day back order. I knew when I ordered them what the back order was and I’m very pleased with Kennedy Americans service and help for ordering all of the parts for the car that I’m currently installing. With a little luck I should be able to pull the car outside tomorrow and maybe start it up to move around and begin rebuilding the front suspension.
Got the leaf springs installed with new U bolts and the restored Lakewood Traction Action bars
Installed the parking brake cables and tied it all together. This’ll be the first time the parking brake works since probably the 80’s.
Driveshaft and brake hose installed. Tomorrow I’ll have to bleed the rear wheel cylinders, install the battery and wheels, and check a few more things.
Also need to wire the shutoff for the Mag. Very pleased the rear is back in the car.
AMC weirdo
1969 SC/Rambler
1971 SC360 Hornet
1968 Rambler Gasser-under construction
1970 A66 Challenger- now 440+6
The Following 6 Users Say Thank You to LetsFNgo For This Useful Post:
69M22Z (03-20-2026), big gear head (03-21-2026), L78_Nova (03-24-2026), PeteLeathersac (03-21-2026), Tenney (03-21-2026), Too Many Projects (03-20-2026)
  #112
Old 03-21-2026, 02:30 PM
big gear head's Avatar
Why not put a set of one piece axles in it? I've seen a lot of those hubs slip on the shaft and leave someone stranded.
Freddie
Old 03-21-2026, 11:16 PM
LetsFNgo's Avatar
So I got the rear end all put together this morning and installed all the J bolts all installed. The traction bars came out really cool. Then I spent the rest of the day getting the car running. Turns out I had it 1 cylinder off when I timed it and installed the wires. So after quite a bit of time retiming it properly and correcting a mistake I made with the plug wires I got it running. And promptly shut it off due to a multitude of fuel leaks. Another hour was spent getting all of the fuel bowl connections to no longer leak. Then fix fuel leaks at the Y.
Now I was able to run it. And had to pull the carbs back off because I needed to lube up the internal linkage between the primaries and secondaries. Got them bolted back on and now it runs and works. I’m not sure if the Dominators will stay, but they sure look impressive on the intake and it seems to idle and move around the yard well. I need to spend more time getting the linkage to return properly so I didn’t drive it today.
I have most of the parts to rebuild the front suspension and after seeing how worn out the rear springs were I’m going to order replacement front springs as well. The new rear leaf springs must’ve picked the back end of the car up 6 inches on the drivers side. And another 3 on the passenger side.
Overall it was a good, relatively productive day. Car will get backed into the garage tomorrow to take the front end apart. And I can work on the drivers door with the car backed in.
Also, for Big Gear Head, 1 piece axles are on the eventual list. I just haven’t gotten to a point where they were necessary. I will order them at some point.
Thanks for reading.
AMC weirdo
1969 SC/Rambler
1971 SC360 Hornet
The Following 11 Users Say Thank You to LetsFNgo For This Useful Post:
69M22Z (03-23-2026), big gear head (03-22-2026), Bill Pritchard (03-21-2026), cheveslakr (03-25-2026), Dave Rifkin (03-22-2026), dykstra (03-22-2026), L78_Nova (03-24-2026), PeteLeathersac (03-24-2026), RPOLS3 (03-23-2026), Tenney (03-22-2026), Too Many Projects (03-25-2026)
  #114
Old 03-23-2026, 04:54 PM
Those Dominators definitely look cool.
John 10:30
The Following User Says Thank You to markinnaples For This Useful Post:
LetsFNgo (03-24-2026)
  #115
Old 03-25-2026, 12:36 PM
LetsFNgo's Avatar
Now that the rear sits up higher I need to start looking for wider slot mags and tires. I’m thinking 15x8.5’s with L60’s would look badass.
AMC weirdo
1969 SC/Rambler
1971 SC360 Hornet
The Following User Says Thank You to LetsFNgo For This Useful Post:
dykstra (03-25-2026)
