Old 02-07-2016, 02:21 AM
You have seen the light - glad to help make your day brighter [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
Old 02-07-2016, 03:12 AM
300deluxeL79's Avatar
300deluxeL79 300deluxeL79 is offline
<object width="425" height="350"> <param name="movie" value="https://www.youtube.com/v/lX5tfRdkoY0"></param> <param name="wmode" value="transparent"></param> <embed src="https://www.youtube.com/v/lX5tfRdkoY0" type="application/x-shockwave-flash" wmode="transparent" width="425" height="350"> </embed></object>
Old 02-07-2016, 04:20 AM
Ryan1969Chevelle's Avatar
Good stuff guys!!!
Thanks RamblinDealer, I used his press to remove the axle bearings and seal rings. I also removed the front lower control arm ball joints, round bushings, oval bushings, front upper control arm cross shafts, and bushings. Other than the two bushings in the upper mounts of the rear end I am done suspension disassembly:-)
I borrowed the neighbors small torch to heat the U-joint housings to melt the blue plastic out to release the caps, this was new to me and ended up in a major safety hazard:-( NO Injuries) I heated a few and the blue plastic exited the tiny holes nicely, then as I heated another one the cap popped out of the driveshaft and banged into the eve trough, my assumption is that the grease inside the cap after being heated lit on fire and the heat/pressure built up under the cap, then as soon as the heat expanded the ring around the cap enough to release it the cap shot out like a rocket:-( I was working almost outside the garage and was staying well back at the time so just a near miss. Feel free to chime in if you know the error of my ways.
I got the rest out without issue, so the driveshaft is ready for media blasting and Powdercoating too:-)
Then I was on such a roll I had the tools borrowed to finish disassembling the rear end, removed the pinion shaft, bearings, pinion seal, outer races of the tapered roller bearings, crush sleeve, etc:-) (just remembered I need to remove the axle seals)
I will post a few pictures tomorrow:-)
Today was a real critical day, I was pretty stuck! Thanks again Terry for the use of the press, that got me going again!!
Ryan
Old 02-07-2016, 12:01 PM
Very nice.....good day and good results.....and very refreshing to not see a million pictures [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img] LOL.
Well done.
Old 02-07-2016, 07:50 PM
I have completed the bushing and ball joint removal.
The u-joints are out as well. Need to remember the yoke goes on the end that is a smaller diameter fpr a shorter distance. (This will make sense to me later;-)
Got the rear apart, except the bushings in the &quot;ears&quot; :-(
Man this stuff is fun!!!!!!!!
Ryan
Old 02-07-2016, 08:24 PM
Now no scratches when you go to install everything [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
Old 02-07-2016, 09:39 PM
Yup Paint is too fragile for me:-)
Ryan
Old 02-10-2016, 06:05 PM
Checked into the driveshaft loop place I had picked out and they no longer make or sell them:-(
Looking for the bolt on type as inconspicuous as possible:-)
Ryan
Old 02-10-2016, 07:29 PM
Rixls6 Rixls6 is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Ryan1969Chevelle</div><div class="ubbcode-body">Checked into the driveshaft loop place I had picked out and they no longer make or sell them:-(
Ryan </div></div>
I may have one of those bolt-on units here, but will have to check.
Took it off a car a few years back, and don't remember if I sold it or not.
If I find it, I'll get it to you.
Rick
Don't text and drive.
Old 02-12-2016, 12:30 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Rixls6</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Ryan1969Chevelle</div><div class="ubbcode-body">Checked into the driveshaft loop place I had picked out and they no longer make or sell them:-(
Ryan </div></div>
If I find it, I'll get it to you. </div></div>
Sorry Ryan, I apparently sold that bolt-on loop along with some other performance stuff awhile back, just didn't remember specifically.
Rick
