Old 07-25-2015, 07:35 PM
kwhizz kwhizz is offline
Default Re: Next Years Power Tour Car
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: kwhizz</div><div class="ubbcode-body">Bow on the package.........LOL.......A nagging little issue that I had with the car since it was put together was that it had a slight tire squealing issue when making a right turn......after numerous alignments and seeing the results that everything was in spec........I accepted it as being normal with the Ridetech suspension........The car rode and handled perfectly, just that slight squeal ..........So.......After installing the same suspension on Gary's 65 and didn't have any tire squeal at all.........Hummmm!!!!!!!......So....after finishing the Chevelle....the Impala has pretty much been sitting in the garage.......But.......I had to resolve that issue...After calling Ridetech and explaining the issue with them and thinking that it might be a Ackerman issue...we checked a few things and I was told to count the steering wheels turns in both directions off of center.......Duhhhh!!!.......1 1/2 turns to the right and 2 turns to the left......When the car was first aligned.....the steering box wasn't centered in it's travel when aligned.......thus.....the tie rods from the drag link to the steering arms weren't the same length ........which resulted in the turning radius error and thus the slight tire squeal..All fixed now.......LOL.....Sheesh.........This car stuff is Hard!!! </div></div>
Another update........We are getting closer..........Two things.........First, I still had a Brake issue......and after having others look at it for a fresh perspective........It seems that the Vacuum Booster supplied in the kit from CPP was too small and I didn't have room for a bigger one....so ...the car is at Frame-up Street Rods getting a Hydro-boost installed......That should take care of the Brake issues.........Then I still had Ackerman issue when turning the car.........After talking to Donnie at Frame up it would seem that the only thing left that could be causing a problem would be if the steering arms were incorrect........Mark Webster sent an extra set he had to compare them...........Again.......The Nu Yawk factor came into the picture.....LOL........Wrong steering arms on the Nu Yawk Survivor car..........Those crazy Nu Yawk guyz will do anything for a laugh.........Now.....After 3 years we will finally get the Nu Yawk out of the car......(I Hope)
Ken
Old 07-25-2015, 08:43 PM
And it still looks bitchin'! [img]<<GRAEMLIN_URL>>/headbang.gif[/img]
Old 09-25-2014, 07:53 AM
jannes_z-28's Avatar
jannes_z-28 jannes_z-28 is offline
I had the same thing with my Camaro when I bought it. In my case it was more like one turn right and two turns left. It had a very large turn radius going to the right :-)
Jan Suhr
Stockholm, Sweden
1969 Camaro Z/28 ProTouring
My Car My Book My Photos
Old 05-19-2015, 02:50 AM
napa68's Avatar
napa68 napa68 is offline
This post(and many others) have proven to be invaluable! I have the same crappy rear set up on my 59. I was chasing some noise in the rear brakes (after I straightened out the master / booster issue) now that the rears work the way they should.
I thought you had a post about this set up................so I looked it up................and JACKPOT!
All of your work and grief provides more than just some entertainment for myself and others!
BTW, aren't you due to build another car? [img]<<GRAEMLIN_URL>>/dunno.gif[/img]
Thanks Ken!
After taking everything apart.....again.........I found out how untalented I am..........Here's what I found.....when I installed the rear pads there is a stud on the inside face of the inner pad that was &quot;SUPPOSED&quot; to key into a slot in the piston......Sheesh!!!
This car stuff is hard!!......I also ordered a new set of axles as the old ones had some corrosion in the seal areas and that's what was eating the seals after a period of time...I guess it's just called &quot;Fine Tuning&quot;....LOL
Old 05-19-2015, 08:50 PM
BTW, aren't you due to build another car? dunno
Thanks Ken!
LOL..........Actually......The Impala will be going up for Sale in the near future.........So.....You never know !!!!!!..............
Ken
Old 05-19-2015, 11:35 PM
napa68's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: kwhizz</div><div class="ubbcode-body">BTW, aren't you due to build another car?
Ken </div></div>
A Stielow type LS9 / 427 @ 1000 hp in a 1st Gen Nova. Yeahhhhhh! That's it!
Old 05-19-2015, 11:45 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: napa68</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: kwhizz</div><div class="ubbcode-body">BTW, aren't you due to build another car?
Ken </div></div>
A Stielow type LS9 / 427 @ 1000 hp in a 1st Gen Nova. Yeahhhhhh! That's it! </div></div>
Sure....go find that REAL L89 Black Nova (Wink, wink), gut it and make it an LS9 Beast [img]<<GRAEMLIN_URL>>/naughty.gif[/img]
Old 08-03-2015, 12:13 AM
Again.......After driving the Impala for a couple years and getting used to the Brakes as they were......I just accepted the Braking system as it was.......After getting other people who are a lot &quot;Smarter&quot; than me involved to resolve this issue......It was recommended to install a Hydro-Boost system in the car which uses the Power Steering pump and fluid as a power source.....Just got the car back with the new system installed....OMG!!!........I love the car again........I will never use a Vacuum system again.......I never anticipated the Brake stopping power the car really had......
Ken
Old 08-03-2015, 01:31 AM
Great to hear! You should &quot;stop&quot; by AZ sometime [img]<<GRAEMLIN_URL>>/smile.gif[/img]
Old 08-03-2015, 01:38 AM
Now after having a Supercharged LS in the Chevelle how long does everyone think this car can stay like it is ? Will he convert. it or sell it ?
