Old 02-21-2006, 02:54 AM
scott s scott s is offline
Default Re: Needing reassurance on purchase
Iam sure we have all taken our lumps in what ever deals we have done cars,houses, whatever etc??But somewhere sometime we must all grow up and take responsibility for our actions because someone won,t always be there to hold our hands if it dosen,t go our way.Its taken years of car collecting and hard lessons to gather the knowledge that i personally and most of the board members here have and we still have lots to learn,imho if the seller wants to kick some money back to the buyer he,s a hero in my eyes.....
Old 02-21-2006, 02:56 AM
Good, then the posts accomplished the goal. Cool.
Old 02-21-2006, 03:38 AM
Jeff H Jeff H is offline
Have you checked for the partial VIN down by the oil filter flange? That's the first thing I would be doing, check to see if it truly is the original motor. That will make a big difference in value and could help you decide if you want to keep the car or not. The car is a great color combination and the original motor will help even more.
Old 02-21-2006, 04:12 AM
Grusum Grusum is offline
I am going right now to try and see whats there. Should I also find a partial vin behind the heater core on this year camaro?
Old 02-21-2006, 07:30 AM
Belair62 Belair62 is offline
Here is my take on a situation like this...Grusum...when the car got there it was not what you expected. I have bought cars sight unseen and they are never what we envision.Work something out with the seller. If it's a real 70 Z in Daytona yellow you have a very cool car. Play with it...work on it...put money in it...enjoy it...down the road you will be glad you did.
Old 02-22-2006, 02:46 AM
I took the blower motor off..........no numbers on that flange. Checked for the partial vin above oil filter....nothing there either. Tried to take heater core box off but was unsuccessful, broke a couple of studs and quit while I was ahead.
Old 02-22-2006, 02:57 AM
Point of Information Regarding Norwood VIN location......I bought my current 70 Norwood Z-28 in 1978. I will tell you that I found my VIN stamped on the left side of block in the area between the two soft plugs. I can't explain why or how, but it is true.
I dont have picture at this time, but with enough doubters I will do so......
Chuck Sharin
[email protected]
69 Camaro COPO &quot;recreation&quot;
Old 02-22-2006, 04:51 AM
Here is a photo of my 72 T/A (with a/c). It actually has the VIN stamped in two spots, the traditional a/c equipped location, vertically, to the left of the heater box opening, and in the non-a/c location: horizontally under the circular fan motor hole. It is very hard to get to these spots: you have to remove your heater box to do so, which can also require removing the pass side inner fender to access all of the studs.
Old 02-22-2006, 04:54 AM
Did you get the casting # and casting date from the engine? I'm guessing that if the engine code and date stamping are real then the casting date on the block will fall in line as well. I would check with some of the 2nd gen gurus here to see if they can help out a little more.
Old 02-22-2006, 05:23 AM
Jacsey 70Z Jacsey 70Z is offline
This is where you should find the VIN behind the blower motor, also a picture of my oil filter flange. They kept trying about four times, also notice the inspection crayon mark.
See it on the inside left?
Jack Seymour
1970 Z28
Hugger Orange
20K Mile Survivor
