Go Back   The Supercar Registry > General Discussion > Mopar
Old 12-26-2017, 02:19 AM
Originally Posted by RJS View Post
Is the upside down # to the right 1608?? If so then I'm confused Chrysler used 3 digit in 61-9 Example 349 would be 34th. week of 1969.
Also if you need wiring you have to go through Year One or Classic since M+H doesn't sell direct for Mopar.
I used to buy these with electronic guts and then buy an NOS and swap covers.
https://www.ebay.com/itm/Mopar-Volta...-/121703672807
Hope some of this helped
Ron
Ron thanks for the help. Lots of good info.
Not positive what the date code is on the VR. Now that I look at the number it may be 209. Would that be the 20th week of 1969? If so then a replacement?
I have bought all new wiring for the car mostly from Year One except for one wiper harness and automatic transmission harness which those came from Evans via Dante's.
Yes, I have seen the electronic VR's and considered switching the tops especially for my 69 Camaro's. Easy and cheap, came with the mid year Vettes.
Thanks and will keep you posted on the list you provided.
65 Corvette Coupe L78
69 L71 Roadster Survivor
69 Z/28 RS (Sold)
69 Dodge Charger R/T
70 W30 442 Auto Air Survivor
70 Z28 4 spd 4th owner CA car Citrus/Green Cloth
2016 Z06 Coupe M7
70 AAR Cuda (Sold)
69 L78 Chevelle (Sold)
Old 12-26-2017, 01:55 AM
6t9chgr's Avatar
6t9chgr 6t9chgr is offline
Thanks for the link to this thread Ron.
OP...very cool 69 R/T you have there! Mine was originally R6 as well. (Black top, interior also but V88 stripe delete) One day ill go back to the original color
Mine was originally an AC car as well. Curious as to the reason you made the discharge hose 2 pieces instead of the original one piece design? I see you had the hoses replaced...were they not able to keep it one piece?
Heres a few pics of mine...I took the liberty of adding a few factory options to mine over the years (V21 hood treatment & J45 hood pins, electronic ign, charging etc) Ive had her for over 20 years and after a while you get bored of just putting gas into her LOL Swapping wheels etc only goes so far!
I enjoyed the pics of your resto and it looks like a lot of care & attention to detail went into her! Good luck!
Old 12-26-2017, 02:28 AM
Beautiful car 6T9chgr. I understand the liberty's taken. I had a 68 Charger that I took a few liberties with too. Was a great driver. At times wish I had it back in addition to the this car. I have known this car since I was 16 my neighbor owned it. I am the third owner and all original NC car garaged most of it's life.
Not sure I understand your question about the discharge hose. Help me out there. It is late and have had a long day so that very well could be the reason for my question!!
69 Z/28 RS (Sold)
2016 Z06 Coupe M7
70 AAR Cuda (Sold)
Old 12-26-2017, 09:24 AM
6t9chgr's Avatar
Looking at this pic, you will see near the battery, that the discharge hose off the compressor is one piece (steel-rubber-steel)
In your hose there is a removable joint where you can separate the steel part from the rubber...effectively making it a 2 piece hose....
Old 12-26-2017, 02:27 PM
Ok gotcha. Simple answer is that is the way it was. When I started the resto, there were changes to the AC lines where they had been "amended" over the course of the cars life. My ac guy made new rubber hoses and also installed better...clamps?? Around the rubber hose? The clamps that were on there were not a good design as he said. They were prone to leak freon. Clamps is the wrong word. The metal piece that is crimped to hold the hose on. My old crimps sucked and this is a better design.
Let me know what else you see that is wrong. I want to put everything back correct. I see where my ac line is painted black and should be silver. The line from the compressor going over towards the passenger side of the engine compartment.
69 Z/28 RS (Sold)
2016 Z06 Coupe M7
70 AAR Cuda (Sold)
Old 12-26-2017, 01:49 PM
RJS's Avatar
RJS RJS is offline
6t9chr is a good friend of mine and I couldn't wait to show him your thread. He is a full of Charger knowledge among other things!!!
Yes your right your date code is 209 so must have been replaced early on in life.
I want him to put his car back to R6 but he decided to put 2 kids through college, live in a house and eat instead.
Ron
1972 SATELLITE SEBRING PLUS
Old 12-26-2017, 02:29 PM
I have been looking long and hard for ac compressor braces. If you know anyone that has the correct ones please let me know. I have a pair but unfortunately they are wrong.
69 Z/28 RS (Sold)
2016 Z06 Coupe M7
70 AAR Cuda (Sold)
Old 12-26-2017, 07:47 PM
6t9chgr's Avatar
Yes those are pretty much made of unobtanium. I got my set in a package deal with the hoses etc. When I bought my car 20+ years ago, all the underhood AC stuff was missing. Finding & buying back 440 engine, one year only stuff is quite costly!
As far as the AC hose crimps, yes the serrated style is the more modern crimp that can handle more PSI. The original circular style crimp is no longer available as far as I know....
I dont consider my car "correct" but I tried to make it "stock looking"as possible.
Looking over your pics I do notice that you dont have the "correct" valve cover studs on the front & rear lower positions...you have bolts all around.
Also, hard to see in the pics but do you have the special battery cable clamp that bolts to the back of the compressor bracket? (circled in the pic)
Also for 69 440 with AC the throttle return spring should be green...
Old 12-27-2017, 12:08 AM
Ahhhh...I am glad you mentioned the clip for the battery cable that mounts to the back of the compressor. I do have it!! But need to install it. I noticed I was missing that but forgot to install. Will get that installed before I forget again.
I had the correct studs in the valve covers before I had the engine rebuilt!! Damn, I guess the engine rebuilder did not put them back. I was so happy to have had those and survived all these years. Thanks for pointing that out. Another fix🤔.
69 Z/28 RS (Sold)
2016 Z06 Coupe M7
70 AAR Cuda (Sold)
Old 12-27-2017, 12:20 AM
Ok, I need a little help with these ac heater box vacuum lines. Unfortunately, I did not take these off. If I did I would have a ton of pics. I have read the FSM and have got a few clues but really need to understand where the red stripe hose with the “T” goes and where the red hose goes in relation to the top or bottom of the actuator. Or any clues you guys may have.
A12Pilot has been a ton of help with this project....where you been???....RJS 6T9Chrgr you guys have spring on the scene lately with a great round of info. Thanks so much guys super helpful to this novice Mopar guy!!!👍👍😁
69 Z/28 RS (Sold)
2016 Z06 Coupe M7
70 AAR Cuda (Sold)
