Old 09-19-2013, 10:24 PM
Default Re: The New, Newer Project Part Tres...
The reproduction New York license plates arrived today. 956-LYS was the plate originally issued to the Enrico when the car was new. I still have the very first registration from the stack of registrations through the years. www.licenseplates.tv reproduces any plate for around $85. They do really nice work.
Old 09-20-2013, 01:30 AM
Nice indexing of the license plate screws, Steve!
Old 09-20-2013, 02:57 AM
OCD at its worst!
I was finagling with the original carb tonight and found this oddity in the fuel inlet. I have never seen a check valve in a filter cartridge before. The replacement Delco filter just has a paper gasket on the end. This rubber seal and check valve was pressed into the inlet of the original filter. It takes some serious pressure to unseat the valve. Was it an anti drainback valve?
Old 09-20-2013, 03:17 AM
67 442 67 442 is offline
I find these in Oldsmobiles all of the time and yes it is an anti drainback valve.
Old 09-20-2013, 01:43 PM
I wonder what the efect is on flow restriction into the carb?
Old 09-20-2013, 02:09 PM
napa68's Avatar
napa68 napa68 is offline
It was my understanding Steve, this was to prevent fuel flow in the event of a rollover. It takes fuel pressure to overcome the spring.
Tim
Old 09-21-2013, 12:04 AM
I want to give a shout out to members &quot;KevinW&quot; in NJ, who found the Milwaukee craigslist ad for two NOS tires, and &quot;67442&quot; (Paul) in Wisconsin who then proceeded to play the middleman and run down to the seller's shop and pick up the tires for me and then wrapped and shipped them to me. I now have a full display set of 1973 date coded Firestone 500 Radials. [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
The original spare (in the middle) and the two original tires (on the left) from the car are date coded the 18th week (late April) of 1973. The two NOS tires on the right were produced during the 25th week (mid June) of 1973, which makes them all perfect for the late July built car. And best of all they all have the unique, early 1973 white Firestone shield logo which was discontinued in late 1973.
I also got a tip from Paul on how to get rid of that white waxy stuff on the tire surface that no solvent would remove. Paul said it was the original mold release material that outgasses from the rubber over time. He recommended using a hair dryer to melt it and to let it soak back in. I used a heat gun set on low and whodathought but it worked great! I would heat the stuff and it would instantly melt into a glossy liquid which could be wiped away. Then another application of heat and the remainder would soak back into the tire!
Here is the original spare before:
And after using the heat. (disregard the white in the treads, that is tire dressing that hasn't soaked in yet)
Old 09-21-2013, 12:22 AM
And before you ask...there is no way in hell that I will be driving on these tires. The recalled Firestone 500 Steel Radials are known to explode while just sitting, on display. There are several first hand accounts of Corvette owners experiencing these tires self destructing while stowed in the underbody trunk wells of mid 1970's Corvettes. [img]<<GRAEMLIN_URL>>/no.gif[/img]
The car will be on display at the Musclecar and Corvette Nationals (MCACN.com) this November. I will be bringing them with me to mount on the car when we arrive. I won't chance the car jouncing in a trailer for 800 miles on these tires. They are like hand grenades with loose pins.
Old 09-21-2013, 02:09 AM
KevinW KevinW is offline
Thats great Steve! Glad it worked out. looking great as usual!
69 327 convertible (driver)
Old 09-21-2013, 02:19 AM
That's cool...Yenko.net members helping each other out!
