Old 12-28-2015, 11:08 AM
DW31S's Avatar
DW31S DW31S is offline
Ryan, I can't remember if your car came with a blowproof or stock bellhousing? If it didn't, and you're planning to go racing, get one that is appropriate. A lot of improvement has been made in the clutch area over the years compared to how those cars were raced back then. I had a bad experience with Center Force, but I'm sure others will speak highly of them. Do your homework and research and seek opinions before you pull the trigger on purchase and installation. Also, see what your trans. guy thinks about changing the 1st gear ratio. I think your M20 should have 2.52; if it doesn't, see if your guy can make sure that it does or maybe even something a bit steeper when he does the rebuild. That car is heavy and the lower (higher numerically) gear ratio will help get the mass moving.
Old 12-28-2015, 12:17 PM
Ryan1969Chevelle's Avatar
Thanks Dave.
I am researching this item thoroughly, and want a really fun street clutch with the ability to drag race occasionally. So far 10 spline Hays Street/Strip is the one most recommended but 10.5 or 11 inch is still up in the air.
The stock bell housing is on the engine right now, but I agree that rotating mechanical mass is a hazard.
I will get one for the PSMCDR drivetrain for sure. USED would be fine with me, I won't have to certify the car and there is not even a requirement to have the SFI approved scatter shield bell housing in pure stock.
"Manual Transmissions
The transmission must be correct for year, make, model and engine of the car. 3-speed manuals may be upgraded to the correct 4-speed if originally available. Aftermarket H-pattern shifters are allowed if no modifications to the floorpan are necessary. Line locks are not allowed. Scattershields are okay. No conversions from column-shift to floor shift allowed unless available as a factory option. Aluminum flywheels are NOT allowed."
If anyone has a USED one similar to this one for sale at Summit send me a PM.
http://www.summitracing.com/int/parts/la...ype/muncie-m-21
Ryan
PS: Noticed this rule that I might as well prepare for as well
From the PSMCDR Website....."Driveshaft safety loops are mandatory on all cars 13.99 and faster! I like the style that doesn't require holes to be drilled in the floor:-)
Old 12-28-2015, 02:14 PM
Note from Nick.
"Your trans has the 2.56 ratio.
Nick
Gear Tooth Count
Gear Cluster Ratio
First 36 17 2.56
Second 30 19 1.91
Third 27 22 1.48
Fourth 24 29 1.00
Should be very good on the street:-)
Ryan
Old 12-28-2015, 02:43 PM
Item Year Month
Purchase and Documentation 2015 Feb
MCACN Barn Find Display 2015 Nov
Body removed from the frame 2015 Dec
Frame 2016 Jan
Suspension 2016 Feb
Steering 2016 Mar
Rear End 2016 Apr
Brakes 2016 May
Fuel System 2016 June
Engine 2016 Sept
Transmission 2016 Sept
Exhaust 2016 Oct
Body return to frame 2016 Oct
Wheel and Tire 2016 Nov
Battery 2016 Nov
Fluids 2017 Jan
Trim 2017 Feb
Interior 2017 March
Jack 2017 March
Certification 2017 April
Touch up scratches (Paint) 2017 April
Drive to Al Stager's place 2017 June
and take him out for ice-cream
This is my schedule.......I thought it would be cool to look back on it..........
Ryan
Old 12-28-2015, 08:01 PM
What happened to July & August 2016? What Vacation? Did you not explain to the family....there will be no vacation in 2016.
What happened to December 2016? What Christmas? Did you not explain to the family....there will be no Christmas in 2016....do they know you have a car to finish? [img]<<GRAEMLIN_URL>>/dunno.gif[/img]
Just having fun [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
I hope you make ALL your goals.
Old 12-28-2015, 08:23 PM
You picked up on that!!!
I had a full Grinch schedule dreamed up, it was a wonderful awful schedule:-)
Ryan
Old 12-29-2015, 03:32 PM
Without the support of all my friends here on yenko.net and 2doorpost.com I would have never even considered buying my W-31 Post Car!!
At the end of this chassis restoration I will be a self proclaimed amateur, right now this is all 100% uncharted territory for me. I am car crazy for sure but have done very little work on cars
This is why sometimes (often) I post seemingly ridiculous details about things I am sure you all know very well..........but for example.........who would think a scattershield wouldn't fit with stock pipes, starter, brackets, etc, etc?
In my hobby as well as at work experience is key, and I appreciate everyone that jumps in and shares their experiences. (Obviously I can't follow everyone's path, I have to chose only one path for each item)
Big Thank You!!
Ryan
PS: Tonight or tomorrow I will visit Sam (W-Machine guy here in Ontario) to buy a few parts share some stories and take a few pictures of details on his survivor 1969 442 W-30, 4 speed, Holiday Coupe, Glade Green, Black top, gold/tan interior The clutch linkage, as mine is all &quot;funcky&quot;, and I also want to see if it has (boxed rear control arms, a sway bar,) and frame tie bars? (Inline tube sells them for $65.00 US/$87.00 CAD)
online.flipbuilder.com/wmmk/nfjp/
Ryan
Old 12-29-2015, 05:08 PM
The Dude The Dude is offline
I have a scattershield if you are interested. Came off my 65 F85 442, its on the right. Has the sandwich plate with it.
Old 12-29-2015, 06:00 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: The Dude</div><div class="ubbcode-body">I have a scattershield if you are interested. Came off my 65 F85 442, its on the right. Has the sandwich plate with it.
</div></div>
Thanks for the offer, please PM a price but I feel it best to let this item sit for now and get the stock set up going before jumping into this Day 2 item.
If super reasonable of course I would buy it for future.
Ryan
Old 12-29-2015, 05:56 PM
83hurstguy 83hurstguy is offline
I know you have your eye set on a few engine builders, but I recommend you at least consider/talk to BTR Performance in Rochester, NY. I didn't realize how close you are to his shop, and Bill is definitely a top notch Olds engine builder, having raced Olds engines for many years. He's also typically backlogged, so if you wanted an engine done next September, should probably at least start calling around now to get in line somewhere.
'68 H/O W45
'70 Cuda
